I got this one.. http://www.amazon.com/gp/product/B00HLCUQFY The center part doesn't look nearly as dark.
Also bought a titanium one which I actually like better (http://www.amazon.com/gp/product/B00AI5FADE). Still deciding which I'll end up using though.
I've been wearing one for the last 5 years; no visible damage to speak of. However it isn't the ring my wife gave me when we got married. That band, a platinum one, is sitting in my safe.
You need a set of vise grip locking pliers to remove a WC ring; biggest you can find for most amount of torque leverage.
First, adjust the pliers so when you close them, they will lock down tightly on the ring. Now open them and tighten them by one screw turn. Grip down on the ring again and lock them. That should break the ring. WC for all of its hardness is brittle and will shatter. Wear safety goggles as pieces of metal may fly
Yeah I was wishing I owned a vise - forgot about pliers. Thanks for the tip!You need a set of vise grip locking pliers to remove a WC ring; biggest you can find for most amount of torque leverage.
$20? That's it?
Never worn a ring, but I'd probably go silver. Gold just doesn't look good to me. Tungsten seems too popular -- lulz.
This is the ring I have: http://smile.amazon.com/gp/product/B008KUYI5U/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It's held up fine so far but I've only been wearing it for a few months.
Didn't want to worry about scratching it up. I think the platinum band was about $1k.Just curious why?
