I agree with
@DAPUNISHER but I would add that I think the sweet spot on NVME value is 1TB.  I would spend a little extra now just to have the extra space/performance for the long haul.  I think it should be like 100% more capacity, a little more perf for about 50% more cost (or less).
I don't know what your PSU options are, but if you are ever going to add a GPU you might consider bumping up just a bit or going for gold rated unit.  I mean, you never know.  This time next year you might be able to get a 1070 for like $100 or something.  The 500W Bronze is likely going to serve you well even then but it's just something to consider, especially if you could get a few extra watts and gold rating for maybe $10-$15 more.
