toyota
- Apr 15, 2001
- 12,957
- 1
- 0
Originally posted by: garkon
Slitherydee, i'd think your system should run GTA4 just fine, with decent settings even. Have you gone into the menus and disabled the "always record replay" setting?(or something which sounds similar). I got a huge boost in fps from that setting being disabled.
edit: i'm on a c2d e6600, 6 gigs of ram(only 3 utilized by vista), gtx260. After switching the setting it went from unplayable to fluid.
what do you mean "only 3 utilized by vista". if you are using a 32 bit os then Vista has nothing to do with it and you should not have installed that much ram.
