thecoolnessrune
- Jun 8, 2005
- 9,671
- 580
- 126
My company uses Nimsoft NimBUS Monitoring for the entire monitoring network comprised of over 20,000 devices and well over 400,000 data points. I haven't had use of the newer replacements but I will say our current system does a good job (even though it is obviously getting closer to its sprawl limits).
Not only do we have Robots on everything from Windows, iSeries, Linux, AS/400, etc, but there's also SNMP monitoring for Networking devices. We also have an extensive log analytics engine that receives and archives logs from devices (primarily network devices and ESX hosts) while running through analytics engines to scrape for trouble issues. The whole system is ran by a small army of SQL servers (over 12 currently), and Nimbus hub servers (10) leading to 2 root servers, along of course (and most importantly) with our excellent Dev team that keeps the probes, log systems, etc, optimized and always getting better.
For many of these monitoring systems, if you do not have at least a small group of software developers to help support the system on your network, you're going to be paying a lot to the companies to enlist their support in developing the little customized bits and bobs you'll likely run into in various deployments
