shrewdgamer
I'm new. I didn't know J2900 is BGA. I thought you could fit a graphics card like regular desktop.
BTW are Phenom X4s and Core2 Quads better than Jaguar?
Yes, they have higher performance. They also have much higher power consumption.
@AtenRa
Don't know. It is my brother's computer with Windows XP 64-bit, when I try to install CPUz it is showing that I need administrator permission or something like that.
If it's your brother's PC and he won't let you be an admin, don't go upgrading it!
Ok here are the details. I used CPUz's zip version to find this.
CPU: i3 540
Motherboard: DH55PJ
AMD Jaguar performance with discrete graphics card (dGPU).
AMD A6-5200 2.0GHz QuadCore "Jaguar" 25W TDP, PCIe x16 2.0 @ x4
AMD FX-8350 4.0GHz (4.2GHz Turbo) EightCore "PileDriver" 125W TDP, PCIe x16 2.0
- - NVIDIA GeForce GTX 680 2GB GDDR5
- - 8 GB G.Skill Trident 2400MHz @ 1600MHz (2x4GB)
Aliens vs Predator: HIGH / ULTRA HIGH, AA 4x AF 16x, 1920x1080
AMD FX-8350 + GTX 680: 59.2 FPS
AMD A6-5200 + GTX 680: 58.9 FPS
Tomb Raider: Ultimate AA FXAA AF 16x, 1920x1080
AMD FX-8350 + GTX 680: 54.3 FPS
AMD A6-5200 + GTX 680: 53.1 FPS
source: http://adrenaline.uol.com.br/biblioteca/analise/784/amd-a6-5200-kabini.html?pg=05
now try a real game situation, not GPU benchmarks...
to consider Kabini as desktop gaming CPU makes no sense,
I was thinking Pentium J2900 with a graphics card. Do you think this will be good for gaming. If so for how long? Money and power consumption is very important.
Based on this comment I don't think he should really be attempting to upgrade the system, he will probably break something.It is my brother's computer with Windows XP 64-bit, when I try to install CPUz it is showing that I need administrator permission or something like that.
I've installed hardware previously without breaking anything.
There is no option to upload the pic here. Is my choice of J2900 with graphics good?
