parvadomus
@desprado: I know about the "hardware frame metering" its just old marketing stuff for me. 290/290X exhibits the same problems of nvidia SLI: you need profiles for it to work.
Thanks for repeating the same I said: It took AMD 1 generation to get a card on par with SLI: Hawaii.
Crossfire has a much more troubled history than SLI.
1. NV had hardware framepacing since at least Fermi, and if you don't know what frame times or framepacing means, go look up the Techreport article that started the whole framepacing controversy in the first place. Or see here for why it's a big deal: http://www.pcper.com/reviews/Graphi...ils-Capture-based-Graphics-Performance-Tes-11
AMD only followed suit four years later with the R9 290/290X, and anything lower than that like R9 280X or 7970 or lower, doesn't get the hardware fix. Instead they get a sloppy software fix that partially fixes the issue for single-GPU, or dual-GPU single monitor. It still does not fix the issue for Crossfire+Eyefinity users like me. 🙁
2. If you want to know how bad the situation was from 2009 (and probably before 2009 as well) through most of 2013, see this: http://www.hardocp.com/article/2010/08/09/geforce_gtx_460_1gb_sli_vs_radeon_hd_5870_cfx (GTX 460 SLI beat HD 5870 Crossfire, yes you read that right, two midrange NV GPUs beat up the two best AMD GPUs at the time)
