- Apr 26, 2001
- 31,046
- 321
- 136
You can drop me a gaim at CorporateRec.
I have a few questions that are simple, yet frustrating as hell to get worked out as to desktop placement.
Thanks for your help.
If you wish not to message here are the problems:
1) I cannot delete the trash can icon for /dev/null. I do not need the icon but it will not go away.
2) I want to seperate my the kbar icons from the tasks on the same bar:
for example (#=icons)
here is the kbar-- |k| |#| |#| |#| |#|_________(tasks)____________|1|2|3|4||clock|
I want to chop off the task bar part right after the last icon, and place the rest of the menu up top.
I have seen this done, someone mentioned window shading, etc.
Here is an example: here
Thanks
Thanks
