PlasmaBomb
wbhp? Errr. "Wheel brake horsepower"? That's meaningless.
Yes, whp, I got the acronym wrong.
But since rolling roads measure the power at the wheels and back calculate for drivetrain losses to get "bhp"...
his build threads:
http://golfmk6.com/forums/showthread.php?t=20959
http://golfmk6.com/forums/showthread.php?t=31742
He just told me his mechanic thinks his tune has his timing set too aggressively leading to hot cylinder temps.
I think he's moving on from his toy. He told me he's trying to get a b8 s4 or m3
I just looked at his second build thread.
...Flat top pistons? No 'quench' area (they seem to come all the way to the top of the bore)? Possibly milled head and block?
Did he even try and figure out how much compression he's running? Turbos aren't great on, like, friggin' 12:1 motors.
I'd also ask him how the machine shop did things. Hopefully his head didn't get thrown on an old 'belt sander' machine.
edit: he says his compression is stock. I don't believe that. AND he says stock is 9.6:1.
21psi on 9.6:1? Hope he's running race gas.
http://www.edmunds.com/volkswagen/gti/2011/road-test-specs.html
Front-wheel drive
Engine type Turbocharged direct-injected Inline-4 gasoline
Displacement (cc/cu-in) 1,984cc (121cu-in)
Block/head material Cast iron/aluminum
Valvetrain Double overhead camshaft
Compression ratio (x:1) 9.6
Redline (rpm) 6,200
Horsepower (hp @ rpm) 200 @ 5,100
Torque (lb-ft @ rpm) 207 @ 1,800
Transmission type Six-speed manual
stock specs
Premium + water-meth.
Man I thought I've spent a lot of money making my GTI track ready. Build looked pretty good and he used a lot of high quality parts. I would have just stuck with APR K04 (or even stage 3) and not done water-meth. APR may make less power with their tunes but they are safer as well.
I also would have done an LSD upgrade.
Beautiful car...too bad he's giving up on it. LMK if he's looking to sell any parts! 🙂
So does his stuff look factory? I can't find any pics of stock engine with the head off. I'm really curious about those pistons.
Seems like a lot of work for the power level. Water and meth injection for 350hp? I dunno why he wouldn't have wanted to dial the CR back to give him more options.
Did he keep his stock parts to part it back to stock?
he still has car, but is actively shopping and exploring options. Me and my friends are telling him to part out, cut his losses, and get into something more reliable (rwd, manual, NA). But i'm sure he's also thinking to stick with it because he went all in on the build
I agree that if he went with APR tune instead, he may have not had such issues.
