The_Golden_Man
- Apr 7, 2012
- 816
- 1
- 0
Ya, crippled on both sides. Probably meant to be an HD7850/7870 competitor for the non-Ti.
If 192Bit Buswidth, how to you think it will stack up to 7850/7870?
I think NV will have to be slightly faster than 7870 and 7950. They have had 5-6 months of time to see how both perform. No reason why they shouldn't have faster cards. Once overclocking is taken into account though, I don't think GTX660Ti will be able to beat an overclocked 7950. Personally, I wouldn't spend above $180 for any card with less than 2GB of VRAM at this point.
1.28-1.5GB is borderline sufficient right now in some newer games and once you turn MSAA, it can exceed this easily:
http://gamegpu.ru/images/stories/Test_GPU/Action/Battlefield%203%20Close%20Quarters/test/b3%20vram.png
[IMG]http://gamegpu.ru/images/stories/Test_GPU/Action/Battlefield%203%20Close%20Quarters/test/b3%20vram%204x.png
[IMG]http://gamegpu.ru/images/stories/Test_GPU/Action/Medal%20Of%20Honor%20Warfighter%20alfa/foto/test/moh%20vram%20u.png
[IMG]http://images.anandtech.com/graphs/graph5625/44629.png
[IMG]http://images.anandtech.com/graphs/graph5625/44628.png
Sure, people aren't going to be using a $200-250 GPU for 2560x1600 but even next generation games might come dangerously close to using up > 1.5GB of VRAM even at 1080P + MSAA. Also, making the mistake of buying 8800GTS 320mb, I won't make it again. If 2 GPUs perform within 5-10% of each other, I'll buy one with more VRAM to be on the safe side.
Although some games pre-cache textures into memory which makes it difficult to measure which games actually need > 1.5GB of memory (SKYRIM) and which games use up memory if it's there but still run smoothly even with less memory (BF3).[/QUOTE]
Club3D's 1GB 7850 does very well up to 1920x1200 and only starts to hit the limits at 2560x1600 in some games where a more powerfull card would be required anyway. There are some comprimises at ultra high resolutions but for $189.00, it's a great card for a large chunk of the market.
[quote]The Club3D HD 7850 RoyalQueen comes with only 1 GB memory, whereas most other HD 7850 cards on the market have 2 GB. When I first got the card, I was extremely sceptical whether such capacity could provide enough performance for the latest and greatest titles. Now, after finishing the review, I am impressed. At resolutions up to, and including, 1920x1200, the card is just as fast as the HD 7850 with 2 GB, if not a little bit faster. Only at resolutions of 5760x1080 (Eyefinity), and at 2560x1600 in some games, did we see a performance penalty from the smaller frame buffer. Personally, I don't consider this an issue, because a single HD 7850 is just too slow for these resolutions anyway.
The card not only is fast, but also has a great cooling system. We see significantly reduced noise levels from the card, which means it could be used in a media PC that supports full HD gaming. Temperatures are great too, lower than those of many other "big" HD 7850 cards. Thanks to the lower memory density, power consumption is also down, especially during desktop work. In 3D, we see similar power consumption as the 2 GB reference design, which could be explained by the use of a more cost-effective VRM design. This also means that the voltage controller has no support for software voltage control, but this is not that big a deal in this market segment.
GPU overclocking works great, better than that in many other HD 7850 cards. Our manual overclocking yielded an extra 27% real-world performance, putting the card on the same performance level as NVIDIA's GeForce GTX 580, just a bit lower than HD 7950. Memory overclocking doesn't do so well, because Club3D chose Elpida memory chips which are slightly cheaper, but do not offer as much overclocking potential as chips from Samsung or Hynix.
Club3D's cost savings measures are reflected in the consumer price, which is $195 when converted from euros to dollars, as the card is only available in Europe at this time. A typical 2 GB HD 7850 costs $230 and won't be faster at full HD resolutions. In terms of price/performance the HD 7850 RoyalQueen is the fastest upper mid-range card on the market today, by a quite big margin. For a serious gamer on a budget, lacking enough money for a GTX 670, this is definitely the card to get. I would certainly I would recommend it to my friends.[/quote]
[url]http://www.techpowerup.com/reviews/Club_3D/HD_7850_RoyalQueen/33.html[/url]
660Ti will compete against the HD7870 at $300. It will be faster and will force the HD7870 to drop bellow the $300 mark.
HD7870 has long dropped past $300 in North America. It's HD7950 cards that are in the $310-330 category GTX660Ti will have to deal with.
There is no way HD7870 will be a competitor to the GTX660Ti since you can already find some versions for $260-270 no problem and if you look hard enough, even under $250. And these aren't budget versions either. Here is MSI TwinFrozr Ghz 7870 for $260.
HD7970 GE versions are going to take up $460+ price level, pushing HD7970 to $400 or below. That means HD7950 will be moving towards $300 mark soon, and become the primary competitor for the GTX660Ti.
They are just moving the Gk104 down to the mid range price it was supposed to be at and in the process making room for the real Kepler cards to occupy the empty $400-$600 price slots. This is why 670 was barely slower than 680 and why 660 will barely be slower than 670. The 660ti will be the only gk104 that makes any sense to buy, and the real 670/680 will release a bit later to occupy the high end like the were supposed to.
Yep. 660Ti>7950 at probably 300$. Seems about right.
Ya, against an 800mhz HD7950. With overclocking, probably no chance.
I'm sure the gtx660ti will overclock pretty damn well, considering it's cut down even further than the gtx670 and shouldn't have any memory bandwidth bottlenecks associated with stock gtx670/680 speeds. It should catch a gtx670 pretty easily. If it comes in at $300, then the hd7950 gets to look stupid yet again.
Is there a GHZ edition out? Reviews are made on stock reference samples. It really doesn't matter how they overclock, it's added value for those interested.
