Any electricians out there? Need help:
Mermaidman
7,987
93
I just bought a Samsung multifunction laser printer, model SCX-4116. Problem: When I plug it in and turn it on, the lights in the room would flicker and the UPS would beep every 12 seconds or so. The problem goes away when I turn off the printer. My old printer, an HP Laserjet 3330 did not cause anything like this.
Notes: The printer is plugged into a different outlet vs. the UPS, but in the same room. My guess is the printer is sucking up a lot of power, but I'm n00bish on this subject.
So--what's the problem? What's the cure?
edit: It was a Laserjet I used to have, not an Officejet.
Nitemare
35,461
4
Originally posted by: Mermaidman
I just bought a Samsung multifunction laser printer, model SCX-4116. Problem: When I plug it in and turn it on, the lights in the room would flicker and the UPS would beep every 12 seconds or so. The problem goes away when I turn off the printer. My old printer, an HP Officejet 3330 did not cause anything like this.
Open circuit or short in the printer sucking up too much current?
aircooled
15,965
I'm not an electrician, but I did stay at a Holiday Inn Express....
I'd return the printer if you have no other known electrical issues.
FoBoT
63,084
15
fobot.com
lasers use much more power than an officejet
my brother HL-1440 does the same thing
try to locate it somewhere to plug into a different branch circuit
when i plug my Brother laser printer into a different branch circuit , my UPS doesn't beep, i don't think the printer is "broken"
Zim Hosein
Super Moderator | Elite Member
65,522
410
LMFAO! :D
Cheers aircooled :beer:
olds
50,128
781
If this happens just from turning it on, I'd suspect a bad printer. Do as suggested and try a different circuit. Preferably one where all loads are turned off.
Double Trouble
103
The overall load for that particular circuit is probably too high. It's not what outlet you plug something into that matters, it's the circuit. Try taking the printer to another room (or an outlet that you know is on a different circuit) and try it there. If you don't get any issues there, it's probably that you have too much of a load on the circuit you currently have it plugged into. Laserjets do tend to suck up a lot of juice.....
Mermaidman
7,987
93
Oops--It was a Laserjet 3330 that I used to own, so I'm comparing laser to laser.
Is there any way to increase the load capacity for a circuit? I can't have the computer and printer in different rooms for practical reasons. I can't return the printer due to the vendor's policy--besides, it's very well-designed and fast!
TitanDiddly
Guest
Dec 8, 2003
12,696
Rewire the circuit completely with lower gauge wire(check the box) and install a higher amp circuit breaker.
Read: "Hire an electrician"
Or you could run an extension cord through the hall... note that just because it's a different room doesn't mean different circuit. Also, one room doesn't mean just one circuit.
CPA
30,322
4
If you want to do this, expect to pay a lot of money because new wire will have to be installed most likely, which means tearing into your walls.
