Anyone know of fixes? I can't use it properly. If I enable APM and try to shut down it reboots instead of shutting down.. if I disable APM then I have to power down manually it says your computer is ready to shut down, etc.. I have to do a special thing when I set up Win2K to disable ACPI or it won't install. I press f6 to load special drivers and then press F7 and then continue.. this disables it. Otherwise I get a blue screen and I can't continue the isntall. It says my BIOS isn't fully ACPI compliant. But Win9x can shut down my computer just fine? I don't understand why. The mobo is an FIC VA-503+. Any suggestions greatly appreciated!
