ants problem
Ylen13
Banned
Sep 18, 2001
2,457
Anyone knows what to use against ants. I have bunch of ants near my kitchen sink and I have no idea how they got in. So what is a good ants spray that will kill them? I do not care if it environmental friendly or not as long as it not harmful to me
Encryptic
8,885
Originally posted by: minendo
Raid.
Raid is good. It leaves a residue that should keep the ants away for a while. Also:
1. Make sure you ventilate the area after you spray
2. If you have pets, I wouldn't use Raid unless you can keep them out of the kitchen for a while.
3. Make sure there's no food, trash, etc. that is attracting them. See if you can follow the trail of ants to see what they're after.
4. Use rubbing alcohol to wipe up the trail of ants. This will kill them and also destroys their pheromone trails.
Ylen13
Banned
Sep 18, 2001
2,457
Raid.
thanks for the tips, i have no pets, i have trash ben in the kitchen but its empty with a new trash bad in it. They are basically around the sink. Tried to follow where they are comming from but no luck.
StageLeft
70,150
In the past I've found a good way to get rid of ants is to mix up a pepsi solution (one liter of pepsi and about a cup of sugar added in) and wipe the floor and walls down with it.
You're BACK!! Is this permanent?
Ylen13
Banned
Sep 18, 2001
2,457
never would have thought of trying that
CaseTragedy
2,690
No wonder ants keep forming the same trail even after I destroyed the previous one with my hand!
