Question Antennas For WIFI
retab12332
77
Motherboard is ASUS Z-390-P. I will use a intel wireless 9260 for its M.2 2230 WiFi card slot. But where do I get the antennas to connect it?
Leeea
3,799
5,566
i mean the other end, where the antenna connects
oh, they will have a standard washer / nut configuration. Your mainboard backplate may have predrilled holes, or templates for pushing them out. Otherwise just find the correct size drill bit and make your own where ever suitable.
retab12332
77
What are those pre-drilled backplates called ? Can I buy them ?
Leeea
3,799
5,566
They typically come with your mainboard. You either have one or you do not. This is the same plate you typically have USB ports, network port, audio jacks, etc in. It is usually slightly springy and rather thin.
Alternatively, you can just put the two holes in the back of your case somewhere in reach of the wires, and mount the antenna barrels there.
Insert_Nickname referenced a kit above, perhaps it has an alternate approach included.
are you sure you would not rather have something like this?:
https://www.newegg.com/p/pl?d=pci+w...r=1&SrchInDesc=bluetooth&LeftPriceRange=18+60
retab12332
77
https://www.newegg.com/p/pl?d=pci+w...4114&isdeptsrh=1&Order=1&SrchInDesc=bluetooth
What is the difference in using the on-board M.2 2230 vs the ones you recommend ?
thecoolnessrune
9,673
583
Your motherboard comes with a Wi-fi capable connector, but no Wi-fi kit. So to connect an M.2 card like the 9260 to the outside, you need the pigtails and antennas. The antenna side are usually RP-SMA connectors. You can source PCI brackets with RP-SMA holes from eBay and the like for a couple of dollars. Likewise, RP-SMA antennas are available from places like eBay, as well as antenna suppliers like Wilson, L-Com, etc. You'd look for RP-SMA antennas focusing on the 2.4 / 5Ghz spectrums.
That all said, the individual cards are sold to allow OEM Integration and customization. If you're looking to put Wi-Fi on your desktop, the easiest way is to ditch the OEM focused 9260 and just buy the Intel Wifi 6 Desktop kit. It comes with the non-CVNi AX200 module, brackets, cables, and antennas.
