Originally posted by: gramboh
Which heatsink are you using? I just ordered a system with a Sonata today, I'll be using 120mm Panaflo L1A's on the undervolt fan connectors (bought 2, might only the rear, depending how hot the Raptor drive gets). I choose a Thermalright SLK-900U for the CPU with a big 92mm Panaflo fan, undervolted it should be pretty quiet and move a lot of air. Try to get a heatsink that allows at least 80mm fans, that way you can get 20-30cfm without any noise.
Right now (as stated in my previous post
I have no problems with the stock Antec fan, I can't hear it. So far the fans have varried from 1400rpm to 1700rpm. I originally thought that the Antec fan should be replaced with a Panaflo/Papst, but I don't see the need for it.
