Hey guys,
I really dont know what to do about this issue. I have called antec and they sent me a new swivel front mount (I had to pay for it because i was trying to rewire the front usb). Here is the issue. I just got the replacement and installed it. Hooked up my Sandisk cruzer and it says usb device not recognized (usb 2.0). I hook up my old sony camera and it works with no issues (USB 1.0). I know this is wired wrong and it is not my doing. Here is the current wiring of my replacement.
N/C---White---Yellow---Grey
Red---Green--Orange--Black
On antecs website this is how it says the case is wired
"What is the Firewire and USB pin configuration for P160?"
USB pin1 VCC red pin2 VCC - pin3 D- green pin4 D- white pin5 D+ orange pin6 D+ yellow pin7 ground black pin8 ground black pin9 block pin10 empty.
Hmmm.... That says 8 total wires? Why do I have only 7????
Here is some more info about what the wires do:
Wire Color Code
COLOR: CONNECT TO:
RED,ORANGE POWER, VCC, SVCC, +5V
WHITE, YELLOW P-, DATA-, SBD-
GREEN, GREY P+, DATA+, SBD+
BLACK, BLUE, BROWN GROUND, GRND, GND
"What is the typical pin configuration of the Antec USB connector?"
The Antec USB connector follows the Intel standard layout. Majority of the motherboards follow the same standard as well. Intel Standard 10pin Layout
Pin 1 = Power Pin 2 = Power
Pin 3 = Data - Pin 4 = Data -
Pin 5 = Data + Pin 6 = Data +
Pin 7 = Ground Pin 8 = Ground
Pin 9 = Key or Blocked pin Pin 10 = Ground
Taken From
http://www.antec.com/us/support_productInfo_details.php?ProdID=81600#
That is not how mine is wired at all. Also i know this is not the firewire connector. The firewire has a blue wire and a thick white wire.
Does anyone else have this case and have the same issues?
I have even attached pictures of the connector:
http://img.photobucket.com/albums/v163/pc_man83/usb2.jpg
http://img.photobucket.com/albums/v163/pc_man83/usb1.jpg
What should I do, This is a replacement and i had the same issues with the original.
Please help me.
Wire Color Code
COLOR: CONNECT TO:
Taken From
Please help me.
