i think its possible, there are 2 little pegs above and below the edge of the door that it attaches to. all you would need to do is put those on the other side -- drill a couple of holes and put some pegs in. the lock would almost definitely need to go though.
the door comes off easily, i take it off pretty much every time i do major maintenance.
