birthdaymonkey
Second update.
The little gripes aside(only thing I'm truly sad about is the broken latch...), the case has made a noticeable improvement in my system noise.
When I play around with my gpu fan at 25-60%, the noise difference isn't as pronounced as it was in the Antec. It seems that my psu got louder(but probably just subjectively louder because everything else got quieter?) and even after oiling it, it's still producing too much noise. Time for another~ upgrade 🙄
One of the case fans seems to have bad balancing, considering that it's noticeably louder than the other.
Overall I'm pretty happy with the case.
Thanks again for all the input guys.
Seasonic X-series PSUs with Sanyo Denki fans... they're pricey but an easy choice if you're after quiet operation. They have a 460 watt fanless model--and the ones with fans don't even turn them on until you put a significant load on the system.
