Originally posted by: jmolayal
I actually did drain the radiator and overflow using a vac attached to my air, but it obviously couldn't pull everything. Probably could have done a better job of it.
Sucked up everything in site immediately after the pics.
My plan was to get the heads done, put em on, put in new plugs, change the oil and filter and THEN fire her up. Not a good plan?
Did you even check the compression of the Cyl's first?
You need(should have) to find out what is wrong first beofre you start pulling your engine apart.
