- Dec 1, 1999
- 560
- 3
- 81
Im connected on internet via an extern DSL modem...so you could say my computer is connected to the net via my onboard network card. I have tryed to disable it..no change.
You have a software firewall running at all times then, I hope?Originally posted by: Le Québécois
Im connected on internet via an extern DSL modem...so you could say my computer is connected to the net via my unboard network card. I have tryed to disable it..no change.
Im connected on internet via an extern DSL modem...so you could say my computer is connected to the net via my onboard network card. I have tryed to disable it..no change.![]()
BTW, for those who want to see what I get when the computer crash..here's a screen i took with my cam.
Crash!!!
Crash!!!
:Q
That's not a normal crash.
That, to me, looks like video card or memory.
Crash!!!
:Q
Yup I concur........ beg borrow or steal a different video card and try it!
Here is my dumb ideaDid you check your PSU to ensure that the 115-volt / 230-volt switch is in the right position for your region? You use 230-volt in Canada, is that correct?
Even if the power supply volt switch is set correctly, I would doubt that this power supply is sufficient to carry your hardware. Try a PS near 500 watts and I bet your problem will be cured.
Crash!!!
Daishan....did you look at the picture of the crash.......quoted above so you don't have to look for it.....not PSU issue....definately a vid card issue!
Originally posted by: g33k
1.55v is a little high for 2400mhz, but nothing wrong with it, its still safe voltage. I would take wpshooter's advice and go down to a local retailer with a good return policy and start testing different components.
