Another One of These =)
NewDestination
19
hmm..Interesting theorys on Tt. and akugami appreciate the detailed feedback I will definatley look into the parts you listed. And newegg didnt have 3500 venice core that was retail only the 3200, and btw The whole situation with putting aftermarket HS's and Fans on a cpu scares me shitless to be honest.
CheesePoofs
3,163
Even if your going to OC, you don't need an aftermarket HSF. I OC'd my winny to 2.4 (its max :( ) on the stock cooler.
I agree with akugami on the HD and the DVD burner. I dont' know if I agree with the mobo thing though. Personally, I find onboard sound to be fine on my DFI Ultra-d, and its just the normal cheap onboard chip except it's mounted on its own PCB to prevent electrical interference.
NewDestination
19
What I meant by the aftermarket HSF thing was that Newegg didnt have a retail version of the 3500 venice core they only had the OEM version which doesnt come with the stock AMD HSF
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
I've done retail and aftermarket on different builds. I think retail on A64 is a good idea because the cooler works very well, it's pretty easy to get on, it's fairly quiet, and with the retail package you get a full 3 year warranty on the CPU :thumbsup:
CheesePoofs
3,163
Oh, gotcha ;)
If you don't mind waiting a few weeks, monarch has some Rev E 3500's on preorder
Also, you wouldnt' take much of a performance hit by going with a 3200 or 3000, and neither one would limit you. Plus you'd probably be able to rather easily OC them to 2.2, which is what a 3500 runs at.
NewDestination
19
So now i have switched to teh geil ram, got the 3500 (newcastle) and went ATI , got an OCZ PSU, so is that it, you guys are fine with the other parts?
NewDestination
19
***UPDATE***
MSI K8N Neo4 Platinum Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail ______$142.00
Thermaltake Xaser III V1000A Black Chassis: 1.0mm SECC Japan Steel; Front Panel: Aluminum ATX Mid Tower Computer Case - Retail __$129.50
LITE-ON SOHR-5239S BK RTL Black IDE CD Burner - Retail___$27.00
LITE-ON SOHD-16P9SBLK Black IDE DVD-ROM Drive - Retail__$22.00
SONY MPF920 Black 1.44MB 3.5" Internal Floppy Drive - OEM___$10.50
Seagate Barracuda 7200.8 SATA NCQ ST3250823AS 250GB 7200 RPM Hard Drive - OEM____$135.00
Logitech Elite 967234-0403 Black USB + PS/2 Standard Keyboard Retail__$26.00
GeIL Ultra 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model GE2GB3200BDC - Retail __$184.39
SAMSUNG 990DF Black 19" CRT Monitor D-Sub - Retail __$179.99
Logitech MX510 931179-0403 2 tone 8 Buttons 1x Wheel USB + PS/2 Optical Mouse - Retail__$28.00
Microsoft E85-03013 Windows XP Professional With Service Pack 2 - OEM__$139.95
OCZ ModStream OCZ52012U ATX 520W Power Supply - Retail__$105.00
CREATIVE Sound Blaster Audigy2 ZS 70SB035000000 8 (7.1) Channels PCI Interface Sound Card - Retail__$91.00
Logitech THX Z-5300e 280 Watts RMS 5.1 Speaker - Retail__$125.00
MSI RX800XL-VT2D256E Radeon X800XL 256MB GDDR3 PCI-Express x16 Video Card - Retail__$308.00
AMD Athlon 64 3500+ ClawHammer/Hammer 1GHz FSB Socket 939 Processor Model ADA3500ASBOX - Retail__$267.00
**Newcastle Core Is sold out**
Total Taxed and shipped__$2,200.97
NewDestination
19
Lol come on guys tell me your thoughts on the list, I gotsta go to bed soon, gotta long day of work tomorrow..(sigh) so I can pay for this expensive computer =)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
I like that system a lot better than the first one :thumbsup:
Is there some reason you're skipping the DVD burner now? You can get one for about $50.
CheesePoofs
3,163
That system has a lot more bang for the buck than your original system did.
Is there any particular reason yoru getting XP Pro? From what I've heard (and this might not be true) it basically adds a few features that most people will never used over the home version, but it costs $30-40 more.
NewDestination
19
Well, Fist YoyoYohowsDAjello, I got to thinking and ive come to the conclusion that I would never need a DVD burner. and CheesePoofs Ive read somewhere that the only way to get XP 64 is to have XP pro and get the 64-bit version thru Windows automatic update...but not to sure. lol now I want the 4800 X2 setup =) (sigh) but that will never happen. thanks for comments guys
NewDestination
19
hmm...I fell a little uneasy goin with cheapo geil ram...would you guys really go with this if you were in my position? I value your opinions but I cant help from feeling uneasy lol
CheesePoofs
3,163
You don't need XP pro to get XP 64. With xp Pro, you can get XP 64 for free, but it cancels out your xp pro CD-key, which is BAD. ;) You might want to at least get a dvd drive, many programs are beginning to use them. ANd in your position I would definately get the cheaper ram. IMO, there's no reason to get anything else.
NewDestination
19
Thanks for the info bro. :)
IEC
14,600
6,084
Two things of note:
1) The Thermaltake case is not necessarily the best in value or in cooling, check out some of the Lian Li's and Antecs...
2) The Geil RAM is 3 8-4-4 2T latencies. The 2T is KILLER. In an Athlon 64 based system, you absolutely NEED 1T for best performance, it makes a SIGNIFICANT difference. You might want to check out some OCZ RAM as well.
t3h l337 n3wb
2,698
I would definately want to switch from the Newcastle core to the Venice. If that's not available, the bare minimu should be a Winchester. Newcastles are built on the 130nm process, which eats up more power, creates more heat, and is a bit bulkier than the 90nm processors (Winchester, Venice). Venice also overclocks the best too.
CheesePoofs
3,163
Originally posted by: ariafrost
Two things of note:
Where does it say the ram is 2T? I've looked, and I can't find it listed. If it is 2T though, I wouldn't recomend it (after just recomending it):eek:.
t3h l337 n3wb
2,698
Why not 4x512MB? It's much cheaper. 2x512 Corsair Value Select C2.5 is onlye $85, while the 2x512 G.SKILL C2 is about $100. The Venice core can run 4x512 @ 400Mhz, while the Winchester's memory controller can only run them @ 333Mhz.
CheesePoofs
3,163
That would work except there are no venice 3500's available in retail form.
But I also agree that you might want to consider just getting a gig of ram. Two gigs doesn't seem worth it to me yet.
