It appears as though we have several major problems that must be solved before transporting WUs from a home Q to an offsite Q becomes possible with a CD-ROM or ZIP disks.
Also, thanks Ray for the SETIDriver idea, but the time needed to do that for 50 or more PCs would be just too much
(or i might just be a bit too lazy for that
I think the major problems that have been outlined here, and that I can think of are:
1. Finding the NAMES and LOCATIONS of files that need to be taken from the home SETIQ to the offsite SETIQ.
2. Finding some way of getting a home SETIQ to download the 3000+ (in my case, or much more in the cases of Baz and Indy) WUs to keep a large network fed for a period of a few weeks to a month. There must be some config file SOMEWHERE in the SETIQ directory which would let you make this change.
3. Just thinking, but even a 700MB or 800MB CD would not store that many WUs. Probably in the vicinity of 2800 to 3500. Unless, of course, they can be compressed. (does anyone know if you can zip WU's and how much they zip by?). That COULD be a problem for people having to take 2 CDs worth of WUs with them. (Of course, this would create a massive problem of having to rename ALL the files on the 2nd CD so that they are not the same as the ones on the first CD, based on the fact that they are created with an alpha-numeric order to them by SETIQ)
I just had another random thought. I don't have SETIQ installed on this PC at the moment (i can't get SETIDriver on this PC to connect to it when I don't have a local area network happening). But there is an option in the web-based Tools of SETIQ which allows you to import and export WUs between Q's right? Is there some way that this feature could be used to solve the problems stated in either 1, 2 or 3?
-PieDerro
