Originally posted by: THUGSROOK
this prime95 stuff is soooooooooooo boring.
1 hour to go...........
Vcore set in BIOS to 1.60v which reads 1.568-1.584v idle and 1.488-1.504v under load to get 3673Mhz. I was cooling with a SLK900U / Panaflo 92mm and getting 46-48C load. The SP94 with the same fan and AS5 dropped the temps readings to 42-44C under load. I can get up to 255fsb using 1.5375v in BIOS which reads 1.424-1.456v under load in WinXP using CPU_Z and Probe for voltage readings. The 255fsb setting is where I have been running lately since it drops my temps another 2C and can't really tell any difference with 100Mhz drop. 😉Originally posted by: THUGSROOK
yep, ive finally found a C chip that i like 😎
(IE ~ works well with my ram)
not quite as good as yours tho :Q
what vcore you running for that speed? (3673mhz)
yep, i agree.Originally posted by: jhites
LOL - Maybe we should use some ducking to vent all our PC's to the outside.Originally posted by: THUGSROOK
BTW: i dont know what you guys consider hot, but i am sweating from the heat coming out of my case! :Q
my room temp has gone up 2*C from my puter.
3616mhz / 258fsb on 1.6v has passed 5 hours 😀
gonna try for 260fsb next.....
Originally posted by: orion7144
I just bought a cheapo 8000btu window AC unit for my computer room... Works quite nice since I can set the temp independently of the rest of the house and my PC's temps don't fluctuate as much.
I wounder how much of an affect it would have if I ducted the cold air from the AC to the intake for the radiator?
BTW I know these get hot but every Athlon XP chip I had ran as hot if not hotter than this one.
bios setting of 1.625v~Originally posted by: Thor86
Nice! Is that vcore actual under full load or bios setting?Originally posted by: THUGSROOK
