Originally posted by: Doggiedog
I'm no expert by any means but my boss who is 35 has a stent. He had some heart complications from a botched surgery and needed to get a stent. Unfortunately, his is a first generation uncoated stent which means it may need to get replaced sometime down the line. I believe the new modern stents are coated and much safer than the one he has. He used to be pretty active but he's slowed down quite a bit since he had the stent implanted.
Originally posted by: rahvin
I had a cerebral angiogram 3 years ago. Not a big deal although your thigh is gonna be major sore after they are done. Given your kidney failure I'm sure they will keep you hospitalized for a week or so to keep an eye on you and make sure you don't rupture your sutures. Good luck. :beer:
cerebral :Q They told me it will be out-patient and if I need angioplasty if the angiogram shows clogs It will be overnight.
Originally posted by: Kipper
Have you checked out WebMD? Excellent resource - I've found some good information on there.
If your local library has access to Infotrac you may be able to find more sources on there as well.
Good luck.
Originally posted by: ThePresence
Like I said before, my father has a stent. The only issue that I've heard him discuss, is that scar tissue can build up around the stent and start blockage again. That's why some places now use medicated stents. I'm far from an expert on this, but if you have any questions I can certainly call my dad and I'm sure he'll be happy to answer you.
Well I can answer that one without asking him. He's glad he had it done, because he probably would not be around today if he hadn't gotten it done. He had a heart attack which is why they put in a stent. They actually had to shock him back! :QOriginally posted by: Epoman
Yeah they will use a "medicated stent" it lowers the risk of scar tissue dramatically.
Don't make a call on my account if it's long distance. But if you do ask your dad did he have any reactions to the stent, Is he glad he had it done?
Did he slow down on his own accord or did the procedure slow him down.
Yeah, so I'm quite sure he's glad he had it done. 🙂
Originally posted by: dmcowen674
Yes, best wishes to you and your family.
Question, I missed. How did you get in such a shape at 33 ?
Bad sh!t happens for no reason Dave. Think about how lucky you really are sometime when you aren't bitching about how bad you have it. I had a blood clot at 27 for no apparent reason other than a genetic marker that they only recently discovered. I didn't do anything that caused it (as in lifestyle), it just happened.
Tell me about, my brother is 100% healthy (he's 23) and my mom and dad both smoke a pack a day (55 and 56) and they are both healthy. Pisses me off, I never smoked or drinked or did drugs.
WHY ME DAMNIT :|:|:|:|
They say you won't die because of kidney failure as long as you are on dialysis, YOU WILL DIE FROM COMPLICATIONS OF DIALYSIS. 🙁
All of my health problems are due to my Kidney disease. At 21 I got on dialysis. They could never give me a reason why, except that my kidneys SHRUNK. It doesn't run in my family.
Yes, I know, we're only human.
Glad you recovered.
A Genetic marker for what? Bad Clotting???
Are you on a blood thinner for the rest of your life now?
Originally posted by: remagavon
I had an Angiogram done about 6 months ago and it went fairly well. The only major problem was that it took about 25 minutes to get an IV into my arm due to 'rolling veins', which I warned the nurse about.. needless to say I was ready to rip everything off and walk out before it began! (They ended up having the doctor get it in). It's a really easy procedure after that, just lay still and hold your breath for a few seconds every minute or so as a machine pumps dye into you. Not quite sure why, but it pumped about 1/5th of the vial of dye into my arm right at the end and that was VERY disconcerting, a huge rush of cold solution into your veins is extremely awkward, it felt like my vein was going to burst (but it did not hurt). Also they say it might burn as it goes through you although I did not experience that. Good luck, I've had a battery of tests done over the past few years (originally for IBS and now for hypertension) and I'm only 19. Also don't smoke/drink/do drugs.. not fair dammit! 🙂
Originally posted by: shimsham
its been a while, but i think plasty is where they insert tubes into your arteries and inflate them to open the artery up to remedy blockages. my father and a friend had that done, and they came through fairly easily.
again, im not 100% sure on the exact name, but they handled it without too much trouble.
You are correct. Angiograms tells them the problem, AngioPlasty helps fix the problem as you described.
