OBLAMA2009
- Apr 17, 2008
- 6,574
- 3
- 0
i prefer the physical buttons now. android has more screen space than apple because, among other things, it doesnt have on screen buttons
Will the software buttons meld with the status bar, ala Honeycomb? Will app makers have to re-write their apps in some cases to be compatible with the permanent status bar- ala Honeycomb? Too many questions. I do hate physical buttons though for the light leak.
Between the HD screen and the no buttons the Nexus Prime is going to be a rough ride compatibility-wise for at least a year. I know that is the point- the Nexuses are supposed to push the standard. But it seems that many people have signed on that the Nexus Prime is going to be a superphone finally competing with the polish of the iPhone, when really it might be a usability nightmare for early adaptors.
Meh haven't had any problems with current apps using the on-screen buttons with my nook color. Hardly notice them, and they can be hidden if absolutely needed.
Just read that the Nexus Prime indeed has virtual buttons only. One single home button on the bottom front and power and volume buttons on the side.
Apple might as well just start filling out the legal forms now.....
Why can't the home button be placed on the side? Then the entire front could be a screen.
As long as it's optional, it's a good feature to add. I personally prefer physical buttons for functionality which should always be available.
im not sure why no one likes physical buttons. i can t9 text message much faster than using a on screen keyboard.
As Bober say all will be good if its optional.
I like having the physical buttons on my phone but this would be great for porting Android to the touchpad.
How can you make having physical buttons optional? They are either there or not there.
There is usually more than just the one Android phone model on sale at a time.
I thought you meant on one specific model.
/facepalm
Yes, different models.![]()
Doubt that. I don't see Moto/HTC/Samsung/etc producing two identical models except for physical buttons.
