Anandtech Haswell review is up!
Concillian
3,751
8
I'm still unclear on gaming advantages Haswell has over 3930k. I guess i'll have to keep digging, or realize that the benefit must be so small that no one has posted a huge banner announcing it.
What gaming advantages does any CPU have at resolutions and settings that people actually use?
Most everything from 2500k onwards is pretty close to perfect framerates from the pretty stringent standpoint of frame latency / microstutter / perceived frame drops.
[H] does have some gaming benchmarks for Last Light and Bioshock Infinite. As expected differences between SB, SB-E, IB & HW at the same clock speed are minimal at best.
Enigmoid
2,907
31
Optimized softs have quite a racist opinion.
But since you re suddenly numbers agnostic , theses one should suit you...
Here what happens when all CPUs are more or less treated equally
in respect of their ISAs and architectures...
index.php
http://www.guru3d.com/articles_pages/core_i7_4770k_review,19.html
Well clearly that must be correct because the 2600k only performs a few percent better than the FX 4300 in just about every real world test. And HT brings absolutely no gain. And Ivy bridge was a revolution because its about 41% faster than sandy bridge. :p
Sweepr
5,148
1,143
2011: Intel's crappy IGPs will never beat AMD APUs.
2013: But, but, they cost much more!
Quite a change in 2 years. If Broadwell brings its rumoured 50% graphics boost things will heat up once again in 2014. :)
monstercameron
3,818
i'm not sure that is a fair assessment, the amd a10-5800k(ddr3 2133) still beats the hd4600(with ddr3 2400), however crystalwell is an equalizer which does. Hypothetical, if the a10-5800k had as much bandwidth do you think gt3e would still beat? in any case it does and amd needs to step up their game...
monstercameron
3,818
I think Intel's solution would still come out ahead. I wonder what the respective GPU die sizes are. Pretty sure Intel's 40 EU configuration is larger, and it's on a more advanced process as well.
if having ~2-3x bandwidth advantage only nets 6 frames higher, a 90+GB/s a10 would seemingly be higher...how well really does performance scale with bandwidth?
Concillian
3,751
8
well if you put the frame rate improvement as a percentage you can get your answer.
However, bandwidth scaling is a sliding scale. At some point you get "enough" and more is relatively little performance. Conversely at some point the graphics core is starved and bandwidth is nearly 1:1, so it's not possible to put a fixed number on it. The IGPs tend to operate towards the starved range, since it's easier to add GPU cores to the CPU than it is to add bandwidth.
Abwx
12,017
4,978
12 to 18 being a 100% improvement...
Other than this strange arithmetic it s weird that the 4770 84W TDP
HD4600 is , well , on par with the 35W mobile Trinity GPU....
Feb 19, 2009
10,457
10
Not sure if serious. Cost is always a factor when you try to sell products to the masses.
Iris Pro is $468.. also a $90 premium to make it competitive means its approaching $100 GPU discrete territory, which for desktop users, would blow away Intel's iGPU regardless.
Lets be honest, its an awesome mobile product from Intel, amazing perf/w, and its to be commended. But once you move into desktops, its pricing puts it into the fail category. Desktops aren't limited to ultra low TDP. A 3770K + discrete destroys Iris Pro for less $.
Sweepr
5,148
1,143
And thats a desktop APU vs a mobile GT3e Haswell. Haswell GT3e comes to desktop with 65W TDP which likely allows for higher clocks than mobile counterparts.
Sweepr
5,148
1,143
I seriously dont care about any of those IGPs in desktops. Even in notebooks I'd rather have a $100 discrete GPU than an overpriced CPU+IGP solution.. as you mentioned. I just find it amazing that it took only 2 years till an Intel IGP outperformed AMD's best APU. While its performance doesnt fit my needs, their progress in the graphics space has been amazing in the past 3 years.
IntelUser2000
8,686
3,787
Just like AMD's some secrete ingredient will outshine Intel chips in some fringe tasks? Or how about my 1045T crushing my 2500K when I run 6 encoding jobs concurrently? That kind of relevance?
Your attempt to save anything and everything Intel is pathetic just as these new chips.
What the [heck]?
I never said the desktop Haswell is amazing or you should go buy it or whatever, but what's wrong is wrong. You pointed out Linpack, and I said in that scenario it'll far much better, which is the whole premise of AVX2 in the first place.
No profanity in the tech forums, please
-ViRGE
Abwx
12,017
4,978
Benchmarks are non neutral numbers...
When Intel agreed to help MS optimize Excel we can be sure
that the Intel devellopper put their opinion about the "best way"
to "optimize" this soft , so ultimately the rzesults are influenced
by the devellopper opinions , we are not in pure mathemlatics
where results are independant of humans wills...
Homeles
2,580
Is it just me or do motherboards have a huge effect on power consumption?
It's not just you.
If it performs faster in one application, it performs faster in that application. There's no room for opinion there, regardless of whether or not the application in question is actually relevant to assessing the real world performance of a microarchitecture.
galego
1,091
It looks like a serious problem to me. According to Anandtech there is 11.8% increase in power consumption, with only 13% performance increase. You'd almost get the same results if you just overclocked an Ivy Bridge. What happened to the super savings from the on chip voltage regulator and the improved 22nm process?
Nothing, Intel had announced higher TDPs, therefore we already expected higher consumptions from this 'improved' technology :sneaky:.
tommy2q
60
The review seems kind of short. Load power consumption is pretty bad. Will stay with my 2600k.
Homeles
2,580
Ah yes. Higher power consumption equals technological regression.
I don't think Intel ever had any hopes of pulling away a significant number of desktop Sandy Bridge users to Haswell.
But yeah, the review was a pretty significant departure from Anand's usual brilliant articles.
galego
1,091
Do you believe that TR selecting the more power hungry (Asus) mobo for FX and the most power saving (MSI) mobo for i7 when compared the power consumptions of AMD vs Intel chips was... arbitrary? No.
A change in motherboard can give 20-30 W for the same chip same everything else.
