[AnandTech] Atom Z3770's Cinebench performance
monstercameron
3,818
I was about to say - those AMD APU laptops have pathetic battery life. Have battery life tests been done on Jaguar laptops? All indications I've seen show 4 hours or so. Not impressive, unless I have bad information. If anyone can clarify real world battery life on the Jaguar, please do so.
Bay Trail should do better than the original Atom - which had great battery life but terrible performance. I expect good things here in that respect. I also don't see DRAM as an issue since these are aimed to tablet SKUs, with many of them running Android.
platform power is kinda high but power consumption is decent with temash/kabini
http://www.notebookcheck.net/Review-Acer-Aspire-V5-122P-61454G50NSS-Notebook.93321.0.html [9W idle 18W under load][note: this is temash on an 11: screen]
http://www.notebookcheck.net/Review-Acer-Aspire-V5-122P-61454G50NSS-Notebook.93321.0.html [10W idle 19W under load][this is kabini with a larger display]
I think the power usage is good just not quite optimized.
Exophase
4,439
9
I feel like this has to be said every time.. idle doesn't mean CPU power consumption is nearly 0W. Temash/Kabini is most likely not optimized for low leakage to the same extent Atom and mobile ARM SoCs are. Even AMD claims idle number > 1W. The CPU power consumption at idle very much contributes to the total power consumption at load.
monstercameron
3,818
The original Atom achieved 7+ hours fairly easily and that was on a dated lithography process. I highly doubt battery life will be an area in which Bay Trail disappoints..
Personally, this (battery life) is what excites me the most. I love the fact that an iPad basically lasts forever on a charge, and i'm waiting for something other than the macbook air to deliver similar results. Hopefully Bay Trail will be that product.
both the mba and ipad have pretty large batteries. the ipad 4 has a 43Whr and the mba has something like 53Whr. Also they only seem to have decent longetivity under very light loads, like web browsing. Put them under load like gaming and they will not last much longer than any ol' windows laptops.
Blandge
172
How the hell does this thing use 23W at load? The 2012 MBA only uses 21W while running Cinebench with Ivy Bridge.
Are you telling me that this Temash laptop uses more power than an i3? What has Acer done to cause this.
SiliconWars
2,346
Cheap laptops, cheap components. I've explained this before when people were going nuts over Haswell's low power in the MBA. If you spend enough money on every component of the system you can get some very impressive results. If you don't...
blackened23
8,548
Who the heck games on a portable ultrabook or tablet on a battery charge? A very serious question, not joking. I don't know whether you're referring to lightweight games like Angry Birds or full fledged windows gaming. If the former, that is a non issue as it doesn't affect battery life. If the latter, gaming is by far my last consideration - if I wanted a gaming portable I would get a full size laptop, NOT an ultrabook. Big difference - full size laptops are a million times better for any type of (demanding) gaming, I would never consider an ultrabook for that task. I also would NOT play a demanding Windows game on a battery charge, that sounds extremely stupid to be honest. I do however consider battery life of utmost importance for doing productivity tasks, which is why that (battery life) is worth a premium to me. Unfortunately, AMDs APUs haven't impressed in this respect at all. They're great for HTPCs but not very good for long battery life. And gaming isn't a consideration in either case.
Folks are buying the macbook air in droves because it's a well engineered machine with an enormous amount (12+ hours) of battery life. Gaming is not a consideration in this - most of these people are doing school work, real work, and doing light browsing / media consumption on the side. They're certainly not playing crysis 3, a full laptop is better suited in that case. If not a desktop. Gaming is not why people buy these machines. If you want gaming you look at a full size hulking 15 pound monstrosity laptop - not a 2 pound super thin ultrabook. Come on.
monstercameron
3,818
11" air with smaller screen, ssd and power optimized mac osx
Under load, power draw increases, of course. The peak value is reached at 31.6 Watts. Here, Windows power consumption, at 46.2 Watts, is considerably above the native OS. In comparison to the MacBook 11 from 2011, this test shows a difference of roughly 42%.
http://www.notebookcheck.net/Review-Apple-MacBook-Air-11-Mid-2012-Subnotebook.79125.0.html [7.7W idle, 31W under load]
tential
7,348
642
121
I played gta San Andreas on my laptop from 2006, got 2 hours on the integrated graphics.
Lol bu, if you expect high battery life while gaming then lol.
I want high battery life whole browsing. If I get 16+ on baytrail mobile which is what I'm expecting just from my shot in the dark guess, I'll be extremely happy. Like you said though, I doubt battery life will disappoint.
lefty2
240
9
Some of the Bay Trail stuff coming: http://www.zauba.com/import-ftxi02w0000026-hs-code.html
3x Acer tablets, 2x Samsung tablets, ASUS tablet (T100TA), Dell tablet, Dell laptop, ASUS laptop (X451MA).
That makes sense. Looks like Silvermont will be mainly used for tablets, because of it's low power consumption.
Kabini/Temash is mainly used in cheap laptops, where performance is more important than battery life. So, the main competition to Kabini is from i3 core/Haswell Celeron, not silvermont.
monstercameron
3,818
silvermont has a range of products it could fit in, not just tablets. Remember that there are 10W skus branded pentium and celeron using silvermont cores. kabini/temash has competiton from below[silvermont] and above[ivb/haswell celerons and pentiums]. The only saving grace for amd solution is price and gpu performance.
Ventanni
1,432
142
That looks sick, sick impressive, especially if we're looking at a 2-8w TDP depending on the workload, but according to the article, the Intel representative was careful to only run a single benchmark; Cinebench MT 32bit.
I want to see more benchmarks before I make any decision, although I'm sure this platform will be the start of a much broader x86 tablet market.
lefty2
240
9
Yes, for netbooks maybe, but for regular laptops there is a minimium amount of performance that is aceptable.
BallaTheFeared
8,115
Looks like steamroller arrived early, all aboard the wintel train.. Choo Choo!
Come on man, seriously? Don't do that
-ViRGE
monstercameron
3,818
I do agree with that sentiment but I must point out that a few atoms did get built into small form factor pcs [secondary pcs, nas boxes, routers, htpcs] with the hinted performance it could compete with kabini/temash is many areas.
Vesku
3,743
28
86
I'm sure Bay Trail will find its way into notebooks and desktops, but it doesn't look like it will be worth waiting for over Kabini in those form factors. I'm thinking Microsoft will make another x86 tablet push with 8.1 and these Z series chips.
blackened23
8,548
Isn't Intel also releasing Bay Trail celeron's and Pentiums? The 3770 doesn't fall under either of those nomenclatures, does it?
I'd assume that the pricier SKUs would be more relevant for a full blown laptop. Although, I really think intel will want consumers using ULV core CPUs for that type of purpose. Not quite sure how intel is segmenting the Bay Trail in this respect.
Enigmoid
2,907
31
Looks good. I'm not really concerned too much GPU wise. Even the strongest kabini variants can barely game (and mostly at something like 768 x 1024 at 20-30 fps avg, which really isn't enjoyable). Bay Trail won't have the GPU power but for office tasks/ video playback it should be fine.
IMO AMD's problem with Trinity/Richland and Kabini is that they are in the black hole between having an IGP good for basic use/flash facebook games/video playback/etc. and actually being strong enough for gaming (mobile is barely better than intel but gets clobbered CPU wise, desktop a 760k + 7750 is way better for gaming).
blackened23
8,548
I don't care for APUs either but seriously WHO THE HECK games on ultra portables? Why would gaming even be mentioned? If you want to game, you don't get an ultrabook. Period. Whether it's AMD or intel, you need a full size monstrosity with a mobile dGPU for gaming.
On the grand list of concerns I have when i'm buying a portable thin PC, gaming ranks at the very bottom. In other words, no cares are given. Battery life, screen resolution, and component quality - those perk me up, however.
tential
7,348
642
121
I think CPU enthusiasts need to understand what acceptable performance is for the average user. This bench guesstimates the performance at around a penryn 2 ghz processor. I'm currently using a 2.2 ghz penryn now. If this is around that performance, and this is the TABLET processor, then I'm sure the mobile BayTrail processor will handle Windows easily.
@blackened
I think Intel could screw itself pretty bad if this performance of the BayTrail T being aroudn penryn speeds is true. Because then BayTrail M is probably faster and even better comparing to penryn. It's also supposed to be cheaper than Haswell. So people may opt to use BayTrail over Haswell for cheap 300-500 laptops which would mean less money for intel. This rush to the bottom is hurting intel. I wanted to invest in them but the profit margins seem to be closing in on them.
Sweepr
5,148
1,143
A tablet CPU (Atom Z3770) now beats the 65W TDP ''Conroe'' C2D E6750 (MT performance @ Cinebench). :)
insertcarehere
712
701
@blackened
I would think Intel wouldn't want to sell Haswell in $300-$500 laptops in the first place, and would rather sell the cheaper to produce Bay Trail instead.
RU482
12,689
BayTrail-T, which the Z3xxx is part of, is a neutered version of the Baytrail-M. It will be interesting to see what if the Baytrail-M/Celeron Nxxxx CPUs can do anything to the all but dead netbook segment. Too bad all the pre-launch info has the BayTrail-M CPUs priced around $120-$130...yikes
beginner99
5,318
1,763
Not necessarily, turbo can work on all cores for short amounts of time.
Yes for all we now it was cooled with LN2 and running at 3 Ghz. But I highly doubt that.
Exactly. Have been saying this forever. The people that actually can use the GPU in Kabini like for older games they like is a very tiny niche market. You will not make profit of those people. Intel is more realistic here. Save power and die area.
Richland is also similar. Here I have not even seen something higher than an A6 mobile APU and that one is priced higher than core i3 + dedicated.
LOL_Wut_Axel
4,310
8
Even more impressive when you take into account that there's a noticeable difference in performance between running the 32 and 64-bit versions, in my case 9%:
