That entire article is pretty much worthless. The benchmark suite is terrible. I would no sooner buy a hard drive based on the tests results of that suite than I would a gaming video card based on performance running the same tests.
Correct.
Edit:
Also, the article incorrectly states that the Raptor II is using NCQ. And it appears that author doesn't understand what ncq is to begin with, because they attribute better performance to it in an application where it wouldn't make a difference even if it was working.
Yes, but wouldn't RAIDing the Raptors have similar effect to RAIDing the 7200RPM behemoths? In essence what I'm saying is that the graphs would be very similar, only the performance deltas would be increased, no?
Correct.
Edit:
