LOL... funny coming from someone who refuses to show himself! Is that you GUTB?Originally posted by: DFO
DISGUSTING! Anand is obviously an AMD stockholder and attempting to skew results by equipping the intel system with pc800 rdram! I feel that I can no longer trust anand, and will have to look elsewhere for quality hardware reviews.
He didn't mention it because it's not true. First of all, the 2600+ model number is obviously aimed by AMD at the 2.53 ghz P4. Even if that wasn't the case, I suspect the 2600+ and the 2.53 will be much closer in price than the 2600+ and the 2.8 ghz P4. When a consumer looks to buy something, they typically don't look at two items with very different prices as a comparison. I know that in the minds of a lot of people on this board it's "Intel vs AMD for the performance crown". While this is somewhat true, the real battle is for price vs performance. And as Anand said...
Price? Are you aware that when the 2.8 launches in a couple of days, the 2.53 and the 2600+ will be priced similarly? The price performance will be the same for these two chips. Intel will still hold the performance crown though which is important.
The only way to compare 2 cpus is to use the same chipset
KT266(a) VS PX266
or SIS 64x VS SIS 64x
In the end Anand showd nothing maybe except PC1066 is better then PC2700 !!!!
thats the reason the review was part crap and wrong
SO we are the same opinion its more a platform test then a CPU test!
this way the review was crap
the fact that he used ddr 333 on an i845g, means that it wasnt because pc1066 is not officially supported on 850e.
if you guys recall the i845g also does not support ddr333 officially, until the i845ge comes out . seeing as anandtech has plenty of 850e boards that can support pc1066 instead of the intel i850e that they did use
thus they either didnt have any pc1066 (unlikely as theyve done reviews with 1066 before) or anandtech has some other reason not dont the benchmarks with pc1066
You can put DDR400 in an AThlon system but you're still only going to get DDR266 bandwidth out of it. PC800 being as comparable to DDR333 as it is and Aceshardware using DDR333 shows me that the reviewers tried to use similar performing memory for each platform. The difference is that the P4 can use the bandwidth of DDR333/PC800 while the Athlon can't at present and in workstation applications where all of that vertex data is flying across the FSB, the Athlon sits idle and can't compete with the P4. Just because Intel doesn't officially support DDR333 on its chipset doesn't mean it's not supported with the P4. Sis chipsets run it officially and, unofficially, DDR400 aswell. My guess is that aces used DDR333 is both platforms and anand did similarly with equal performing memory to show that even with the same memory, Intel has an edge in bandwidth intensive applications.
The P4 does require fast memory, true. BUT so does the Athlon as evidenced by the fact that in both anand's and acehardware's review the FSB of the Athlon became saturated with vertex data during 3d rendering. This means that the Athlon does require DDR333 to keep up with P4 in this area (3d rendering) as well. They both require very fast memory. Keep in mind that even though the Athlon was paired with DDR333 it was in effect only DDR266 because of the FSB. The Athlon needs fast memory just as much as the P4 as you can tell from ace's review. I would recommend that you read aces review since he uses DDR333 for both platforms. The review was not bad. You points are not making ANY sense.If you would like these reviewers to IGNORE the fact that the Athlon is stuck with 2.1/sec of bandwidth and say that the architecture of the processor is so great and fast and ignore the fact that this great architecture can't perform in 3d rendering because of the FSB limitation then what you are looking for is a biased review. This is review is great and so is ace's. The ideal review that you have in your head would be an abomonation.Basically , all i can say is that this was a very crappy review. Part of having a good review is being comprehensive and this was not that, this was almost as bad as a zdnet review. its like this new chip was put into some sort of generic review making perl script. oh well, i suppose ANY review is better than none and i'm hoping for a better review later, but whatever...
i think its a system flaw to compare on two diff systems with RD and DDR when DDR VS DDR was possible
Anyway the review its free and for example I still wait to see any 2D quality reviews on a higher level then right now (which is near zero)
There's nothing wrong with it since they perform about the same. IF YOU WANT A DDR to DDR REVIEW THERE IS ONE ON ACES. THE RESULTS WERE THE SAME SO IT OBVIOUSLY DOESN"T MATTER!i think its a system flaw to compare on two diff systems with RD and DDR when DDR VS DDR was possible Anyway the review its free and for example I still wait to see any 2D quality reviews on a higher level then right now (which is near zero)
Again Hardware, it is everyone else?s fault that AMD has no other solution then VIA (poor bandwidth management etc.).Originally posted by: Hardware
