Amsoil says "we're better" with their tests..
skyking
22,810
5,974
We have a low use car that I change every 6 months regardless. Sometimes that is the proper thing. It sits around collecting condensation.
pauldun170
9,515
5,743
I've seen Amsoil pushed for years on various Motorcycle and car forums.
A lot of the same talking points. A lot of "I put Amsoil in and I can FEEL the difference!!"
Typically, tossed in vehicles that people won't keep more than a couple of years, under 10. You get a lot of "Bro...I tore down my motor and that thing was clean. AMsoil rocks!!" (meanwhile you'll have someone who just used plain old dino oil and their motor looks and performs the same after the same amount of abuse and mileage)
I never bought into the hype of Amsoil. I'm not a professional racer and my vehicles do not see any sort of extreme usage where I need to get picky with oil.
In my cars, I stick to whatever meets manufacturer recommendation. In my bikes, I will use whatever snyth or synth blend is on sale. If it so happens that Amsoil is cheaper than what else is available then I'll use it.
I think a lot of Amsoil users by the Amsoil so they can get the sticker to put on their vehicle.
jlee
48,518
223
lol if you just want a sticker, I'll send you one for free. :p I have a pile of them on a shelf somewhere.
Ramses
2,871
4
I'm sure if it was crappy oil someone would have figured it out by now and started a lynching. I'm also sore there are oil analysis out the wazoo both fresh and used on bitog forum if one really wanted to know how they stack up. Amsoil is pretty mainstream among the boutique oil suppliers, there are far more expensive and exclusive to be had.
pauldun170
9,515
5,743
Cool!!
I'll need to rearrange the Type R, TRD, Single obese women + 5 cats, Autobot and Wolfsberg edition stickers on my Camry but I think I can make it fit.
MR2 owners are always the kindest people.
Denly
1,435
229
I usually follow suggested interval UNLESS it is a Turbo then I go 6-7k km per change plus check oil level every 2 weeks. my VW turbo and cooper S burn a lot of oils.
jlee
48,518
223
Cool!!
:awe:
Zivic
3,505
38
I have ran amsoil for years.......
in my evo, I have a journal bearing turbo that calls for a certain spec (high zinc) oil and amsoil is on the approved oil list.
I used it on other vehicles because it's easier to drive to napa or place my order through amsoils site that dealing with the dealer. their ATF meets honda spec. I am not a loyalist, but with their preffered customer pricing, it isn't that expensive. most synthetic oils in my area are over $5/qt and many 6-10 bucks.
it isn't bad oil and it isn't really any more money than others on the market
Brian Stirling
3,964
I change my oil every 5000-7500 miles and use Mobil-1 5W-20 most of the time. I could go to 10K miles or maybe more but I also rotate my tires every 5000-7500 miles so it just make sense to do both at the same time.
So, 2-3 times a year I change my oil, rotate my tires, and inspect the brakes etc. -- not that big a deal actually.
Brian
DVad3r
5,340
I've been using Amsoil for about 7 years now in both my car and bike. I learned about it on my old v rod motorcycle forum. The v rod was pretty popular for burning a bit of oil. After switching to Amsoil from regular Dino I can attest that I found a difference in how the clutch worked and the engine was smoother. In the 30,000 km I rode out on my bike it didn't burn any oil.
From my understanding amsoil is one of the true synthetics while others are just blends and labelled as synthetic.
I've also encountered a lot of people that absolutely love the product or they hate it with a passion being turned off by the way it's sold or calling it snake oil.
Either way, you pay $ 15 per year and can buy it at wholesale cost. It's not expensive when you do the math.
Zivic
3,505
38
I forgot to add that my honda odyssey used to use a quart or more between changes (6-7k miles) on oem honda oil. I think it was a syn blend. I switched to oem amsoil and it uses about 1/2 a quart over the same number of miles. the oil costs about the same
Reactions: vin7mick
JCH13
4,981
66
When doing research for what oils to use in my Miata I found that UOAs of AMSOIL that looked better than anything else, especially their MTL oil. UOAs on mutliple turbo track Miatas showed that it well out-lasted a season of racing, which is damn impressive.
Reactions: vin7mick
thomsbrain
18,148
We may only have Amsoil's own data to judge, but I think there's something said by the resounding silence from every other manufacturer. They've clearly decided it isn't in their best interest to be compared to Amsoil or each other.
I'll be sending in a UOA for a 15,000 mile, severe-use interval on my 250K+ Accord V6 soon. Zero oil additions. Interested to see the results.
Reactions: vin7mick
jlee
48,518
223
Was that gear oil or engine oil? I am debating the trusty Rotella T6 5w40 or Amsoil for my next change.
JCH13
4,981
66
I don't have many on-hand... the manual transmission oil was the stuff you sold me (works incredibly well according to my shifter feel) and here is a UOA for 10W40 AMSOIL vs Rotella Synth 5W40(?) Also note the posters comments on gear oil and wheel bearing grease.
http://forum.miata.net/vb/showthread.php?t=402529
This is a turbo track car, so all wear rates are considerably accelerated compared to a street-driven car.
jlee
48,518
223
Yeah I am happy with the Amsoil gear oil as well (seems about equivalent to Redline Shockproof Lightweight and FAR better than Royal Purple, which introduced new grinds). That UOA looks really, really good. I might step up to a 5w40 or 10w40; I'll just have to keep an eye on oil pressure (spec is 10w30 and I have OE bearing clearances).
vin7mick
How did your 15k analysis do. Are you still using Amsoil?
Hail The Brain Slug
3,888
3,329
That poster hasn't been seen for nearly four years now.
Fortunately between the time when this thread was active and now, the YouTube channel Project Farm came into being and did a giant oil showdown series comparing several brands of oil.
Amsoil was the winner with Pennzoil Ultra Platinum a very close second. Amsoil had the edge in the wear test but PUP had the edge in the evaporative loss test.
If you watch the entire series you can see how synthetic oil isn't synthetic oil and there can be significant differences between brands for cold flow, wear, and evaporative loss.
Personally I buy Amsoil, unless Pennzoil Ultra Platinum is on sale. I use 0W-20 and the PUP is frequently over $40, about the same price as the 0W-20 signature series Amsoil. Occasionally it goes on sale at Walmart for $20-30 and is a no-brainer at that price.
I have a small turbo tuned and modified for extra power so I rely on the formula of Amsoil and PUP to reduce knock/LSPI and keep wear to a minimum since I am very hard on the engine. The exceptional performance of both oils in the evaporative loss test also reduces/slows the buildup of carbon on the intake valves of direct injected engines.
Meghan54
11,684
5,228
And Project Farm's videos are mostly just entertainment.
For instance, PF's "evaporation test" is absolutely an uncontrolled test at best and is just a poor attempt to replicate a standardized scientific test of oil (ASTM D5800) which generates the NOACK number, the evaporation testing of oil.....NOACK is test of an oil sample is heated at 250 °C for 60 minutes with a constant flow of air over it, something not done or considered in PF's testing. Using coffee carafes may actually induce very large variation in testing and there's no standards at all. The more useful info is NOACK, not Project Farm.
The wear test.....a takeoff on a grease test. No oil is ever tested like PF does because it doesn't have any real application to an ICE. But again, PF is somewhat interesting entertainment.....just no real info to be derived from it.
Hail The Brain Slug
3,888
3,329
Well, when we get comprehensive oil testing done by a third party that isn't sponsored by an oil company, we can forget project farm.
For now, it's the only non-sponsored testing I've ever seen. Seems pretty interesting to me his results are very similar to the little amount of laboratory oil testing the public gets to see, mostly sponsored by Amsoil.
If you've got access to data, resources, and testing results I am unaware of I'd love to see it.
Pacfanweb
13,158
59
There is really no measurable difference in any oils. Just use the correct oil specified for your engine, and you're good. You won't see any extra engine life or gas mileage or any other benefit from using Amsoil or any other brand. Even if you COULD find some independent testing to differentiate, it would be irrelevant. They are ALL good, and any differences will be very minor and won't be seen in the real world.
"Blackstone Laboratories has performed oil analysis on hundreds of thousands of vehicles. Recently they decided to take all this data and figure out the one question every auto enthusiast wants to know, "Which motor oil is the best?"
The answer is... they're all interchangeable so long as they meet the oil weight and certifications for your vehicle. Mobil 1, Pennzoil, Valvoline, even the discounted brands such as Walmart's Supertech and Peak will not wear your engine out any quicker than any other brand that meets the basic standards for your vehicle. "
Blackstone is a place where enthusiasts love to waste time and money, sending their oil to be "analyzed". But they have seen it all, and I think their results might be more pertinent than any other tests.
Bottom line is, oil is so good nowadays (and has been for decades now) that it's irrelevant. If you're using the correct viscosity, you're good to go. Nobody has oil-related engine failures, and they have not had them since probably the 70's, unless the failure is from not changing it.
I don't know if Amsoil is better and I don't know if it's not. What I DO know is, it doesn't matter. Use Amsoil. Use Pennzoil. Use whatever you want, but you won't see any difference in how long your engine lasts, runs or burns fuel.
Oil is just a useless thing to waste time and brainpower on anymore.
bryanl
1,157
8
PQIAmerica verifies ingredients in motor oil but does not perform wear tests.
Oil can be formulated to make it perform very well on certain tests, without it necessarily protecting the engine very well.
Torn Mind
12,078
2,772
The most interesting thing is that bacon fat performed really well the lubricity testing by displaying great wear protection. If only he could get some right whale fat, the king of animal fats....
