cmdrdredd
Originally posted by: taltamir
AMD bought ATI on october 06. After which the next 5 versions had major changes and fixing to the installation procdures.. a quoted a few jems from the notes for the following drivers... (6.10 was the last released by ATI itself)...
Those are not the only ones, just my favorites (i am serious, they are... they made my life easier).
v6.11, first AMD version and a sign of improvement:
<a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f......_notes.html#250327"><a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f/67...ease_notes.html#250327"><a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/Catalyst_611_release_notes.html#250327">https://a248.e.akamai............tml#250327</a></a></a>
"Using the Uninstall Utility to remove the display driver or Catalyst Control Center no longer results in portions of third party applications also being uninstalled. Further details can be found in topic number 737-23277"
"Un-installing the graphics driver no longer results in the desktop display flashing when installing the in-the-box software driver bundled with the Microsoft operating system until the system is rebooted a second time. Further details can be found in topic number 737-23692"
before v7.3 the only way to reliably install new drivers was to install them over the old ones TWICE.. once to break them, and once to get the new drivers... OR to boot into safemode and run driver cleaner.... but that started corrupting windows with late v6 because it couldn't handle CCC. WHICH IS NEEDED TO GET THE MOST OUT OF YOUR CARD... and was also a laggy peice of crap at first...
However, ATI instructions called for you to FIRST uninstall the drivers and then install new ones... this is why:
<a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f......release_notes.html"><a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f/67..._73_release_notes.html"><a target=_blank class=ftalternatingbarlinklarge href="https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/Catalyst_73_release_notes.html">https://a248.e.akamai............notes.html</a></a></a>
"Uninstalling the graphics drivers no longer results in some of the files and folders failing to be removed in the Program File folder. Further details can be found in topic number 737-23715"
"Catalyst? Control Center: Creating a profile no longer results in the profile shortcut not being deleted from desktop after uninstalling the Catalyst? Control Center. Further details can be found in topic number 737-26659"
"Installing a newer version of the Catalyst? Control Center over an older version no longer results in the newer version failing to install. Further details can be found in topic number 737-26666"
it was a damned if you, damned if you dont... installing a new version over an old version could break windows... deleting an old version meant it deleted some random files from OTHER programs and did NOT delete all the files from ATI... preventing you from installing newer version of those files...
That is... if you choose to beleive AMD when they say they fixed those problems... maybe they were lying... maybe there was no such problem with ATI's drivers and they... like me.. made it all up because they hate ATI... or maybe they bought ATI, stopped pretending the problem doesn't exist... and SOLVED IT! And now you can install AMD video drivers without breaking windows... starting from v7.3 you can either uninstall safely and then install a new version... OR install the new version over the old one knowning it will properly replace it... either one works now...
There were a few more but these are just some quick examples of I grabbed by scanning a few release notes.. I am not gonna scour every release note out there to find every example... but this is obviously not all in my head considering AMD went and claimed to have fixed the problem.
And why do people insist the CCC is uselss?
Do you know VPU recoverer? it restarts the video card after a crash allowing you to keep playing... recently nvidia introduced the same...
This requires the CCC last I checked...
And vga configuration? god help you if you try it without the CCC... fast write... 4x speeds... etc, no configuration will work properly without the CCC... you have to run it and let it "test settings" to make them stick...
Bare driver can't do that.
And as for "it is always recommended to install this way"... recommended by WHOM!
ATI and nVidia each give instructions on how to update drivers... using spysweeper or whatever it was is not in those instructions... nor drivercleaner pro... in fact I think they say not to use any third party stuff...
So when you run a CPU at 3.4Ghz when it's rated at 2.4 you won't use a 3rd party cooling solution because Intel says it will void the warranty? Good advice...The recommendations come from the community who have the issues. Test labs where drivers are created are donw on clean environments free of any lingering potential issues. You won't see trouble in those testing procedures so when released a driver can still have some lingering effects on a system that has 200 different drivers installed half of which are not used anymore. Clean it out. It's not hard.
