just in case you Intel guys missed it, any P4 faster than a 2.8Ghz will require a 4 Phase power supply. So if you want anything faster you will need a new board.
Anandtech NEWS
Anandtech NEWS
Originally posted by: SuperSix
Originally posted by: Mrburns2007
Originally posted by: amnesiac 2.0
And these run at the comfortable temperature of what, 50000 degrees Kelvin?![]()
They fixed the heat problem from what the reviews have said so they run pretty cool. Besides the P4 requires a HUGE heatsink to stay cool.
Riiiiight.... thanks for playing...
It IS big..........you're right! Now, try this.......take a P4 1.6A and O/C the hell out of it with the stock H/S Fan combo...............then, do the same with an AMD chip and the stock H/S Fan combo.............let me know the results K??????Originally posted by: Nemesis77
Are you saying that heatsink on P4 is not big?
EDIT: P4 heatsink & fan. Looks pretty big to me.
EDIT: P4 heatsink & fan. Looks pretty big to me.![]()
With the new stepping, T-bred seems to overclock about 300MHz with standard cooling. Sure, P4 overclocks more, but OTOH, it needs those extra MHz to compete.
SEEMS is a pretty key word there............do you have on??? Have you done it yourself?????
I have with the P4's and tried with the XP's.................all I'm addressing is the fact that with the P4, you can O/C with the stock H/S Fan and pretty amazingly
................with the XP's you are almost guaranteed to have to purchase a 3rd party H/S Fan combo if you want to do any decent O/C'ing
.............as far as the "new" cips which are released but not "out" yet...................it remains to be seen, but, it seems most used 3rd party H/S Fan Combos for testing and to get decent O/C's they used a water block or similar heavy duty O/C'ing device
I'm sure they will be fine, but, no, they're not the World's Highest-Performing Processor..................![]()
Get used to it???Originally posted by: Nemesis77
What's with all those question-marks? It makes you seem agitated. Are you annoyed because AMD released a new CPU?
Back to the topic. Of course I don't have b-stepping T-bred. They were just released after all. As to O/Cing 1.6GHZ P4.... Didn't Intel already discontinue that model?
You better be, since P4 needs lots and lots of MHz to compete with Athlon.
You don't have to OC it as much since it does more per clock-cycle.
With 3rd party HS/fans they overclocked it 400+MHz. So I assumed that with standard HS/fan it would get about 300MHz. That's not far-fetched IMO.
Like I said, it depends on the app. In some Benchmarks the Athlon wipes the floor with P4, in others it does not. What what do you suggest AMD should say? "We just released a mediocre CPU!". PR-talk is PR-talk, get used to it.
Get used to it???ROFLMAO![]()
I see no point in adressing most of your other drivel
I USE both AMD and Intel..........do you?????
I just find it funny that AMD comes out with a headline like that at this point
but, not with these T-Breds
they aren't the "World's Fastest" now and certainly won't be within a few days.
If you're so blind as to only see the AMD brand in chips
I feel sorry for you being so closed minded because that is certainly how you come across.
I mean I can say that the 2.53 P4's O/c easily to 2.8+
Well, I am used to it......why arent you???? Did you happen to capture Intels release on their latest??? "Intel releases their fastest P4 to date, the P4 2.8Ghz"Precisely, get used to it. Read few press-releases. In each and every one that particular company is decribed as "leader in this field" and their products are "best". How can they all be "leaders"? Like I said, it's just PR-talk, get used to it
No claim of "Worlds Fastest" in there, nor in their last release................by the same token, AMD did not claim thon their previous release either!Why is it to hard for you to comprehend that their use of "Worlds Fastest" is all that is in question??? PR aside, it is not an accurate statement and can not be taken as such unless a disclaimer is added to explain how they arrive at that conclusion.
No..........not what I mean at all!You mean: "I have no valid counterpoints to your arguments so I just choose to ignore them". Yep, sticking your head in the sand is a valid strategy, I guess![]()
What I mean is, it is not worth arguing with someone whom is obviously blinded and oblivious as to what you are saying!!!
Ummm, no, don't believe I will OK??????????????????????????????????????????????Could you stop doing the .............?
So basicly, you admitt you have limited working knowledge as to what you are trying to discuss. That's OK, I can understand that, now, try to understand that I do work with building/troubleshooting/testing systems with AMD & Intel chips everyday.............doesn't mean a damned thing either way, but, at least I do have a working knowledge of what can be expected from both AMD and Intel high end chips...............As to your question.... My personal computer is a Duron machine. My personal server has a 200MHz Pentium Pro, my laptop has 1.13GHz P3m. Do I use Intel CPU's? Why yes, yes I do. Any more questions?
No, not quite as sarcastic as someone with your limited intellect but great ability for sarcasim would phrase it, but, how about "AMD releases their fastest CPU's yet which compete directly with Intel fastest offerings"?????????????????Like I said, what were they suppsed to say? "AMD releases new mediocre CPU!". "AMD releases new second-best CPU in the market!". Sorry, PR doesn't quite work that way.
Unless you are just plain blind, winning "some" B/M's does not "The Worlds Fastest CPU" make...................There are benchmarks where Athlon massacres P4, so they are not completely pulling their claims put of their ass.![]()
BINGO........you're finally reallizing my point....................not that hard now was it??????How do you determine what CPU is "worlds fastest"? What benchmarks will you use? Like I said, it all depends on the app.Add a disclaimer which states chip XXX has been declared the fastest in XXX app. and we have a winner in that particular category! It's not the "World's Fastest" now, nor will it be in a few days, weeks, or months...........there is always something faster or another way to B.M it which makes another faster. There is no "World's Fastest CPU" across the board................
Well, sorry, you're just speaking from lack of knowledge there again! I have and will continue to build and use both AMD and Intel chips and will argue and dicuss qualities of each!And you seem to be blind to only see only Intel-chips.
Sorry once again, but you are incorrect.............if you would take the time to see for yourself, I am active in both negative and positive discussions in both AMD and Intel thread and as stated, I use and work on both daily."Pot, meet kettle, kettle, this is pot"
OK, fair enough, and no, that was an example to show you that simply because the XP can O/C to nearly the same speed as the P4, that in itself is meaningless on many levels since the P4 can also be O/C'ed and because an O/C'ed CPU will not provide as acurate results as one running at it's stock, intended speed. One could take a P4 1.6 and O/C it faster than most Xp's...............does that make the P4 1.6 a better CPU??? Of course not, it simply shows the headroom and capability for a certain CPU.What, a 300MHz overclock? If Athlon overclock 300MHz it sucks, if Intel does the same (lesser overclock if you look at the O/C-%) it proves that they are superior overclockers?
Now, before you jump on that, I acknowledge that generally P4 overclocks better than Athlon does.
If you somehow think I am Intel biased, you are incorrect............I've posted one hell of a lot of facts concerning the XP's and especially the upcoming "Hammer" chips which I think are going to be groundbreaking...........I'm simply pointing out the obvious.....................![]()
So basicly, you admitt you have limited working knowledge as to what you are trying to discuss.As to your question.... My personal computer is a Duron machine. My personal server has a 200MHz Pentium Pro, my laptop has 1.13GHz P3m. Do I use Intel CPU's? Why yes, yes I do. Any more questions?
Originally posted by: BoYRaCeR
Originally posted by: Wingznut PEZ "World's Highest-Performing Processor"???![]()
Originally posted by: hans007
realize that the athlon still doesnt have thermal protection
To my knowledge, Athlon does have thermal protection.
Thought most Athlon motherboards have it nowadays, but the processor itself still doesn't. Not that it happens so often that the heatsink flies off the processor in the first place...
Originally posted by: PSYWVic
I always marvel when I read these Intel vs. AMD threads because, without exception, the Intel proponents are always such assholes.
Originally posted by: kami
Good for AMD. I wish people would put their zealotry aside and realize that more competition is ALWAYS better.
LOL! "Most" claim they are releasing their fastest product to date or a similar statement stating they are faster than a comparable product of different branding........not "The Worlds fastest".And what does that prove? Nothing. All companies claim that their products are the best there is. And yes, that includes both AMD and Intel. If you don't believe that, then you are sadly mistaken.
Well, let's see, I read nearly every press release since they come straight to me through reseller lists from several companies..............So you whine because according to you their press-release is not 100% true? Go read press-releases, they are ALWAYS like that!
Oh, now a question for me???? I'm flattered...........Where did I "admit" that? I just listed what CPU's the computers I personally own happen to be running. How many computers do you own? Besides the computers I own, I work on several computers each day. I troubleshoot 'em, manage 'em, install both hardware and software and I test 'em.I presently have 5 systems in my home......3 Intel (1.6, 2.26, & 2.53) and 2 AMD's (1800+, & 2200+)
I also work on systems everyday...............I have a B/M business and hold service contracts for 5 school districts and several local businesses as well as building/updating/servicing systems for customers in shop and on site.
Then you'll easily understand how unimpressed I am with your credentials.....or lack thereof.............WOW! I'm impressed! *cough*not*cough*.
Well actually, as I have stated, I own my own business and currently employ 7 people. I am not personally going out to do service work myself at the present time because I am still recovering from back surgery complications which left me in the hospital for 29 days in June so no, right now I'm pretty much doing anything I please.............how about you????? Why aren't you working or doing something productive? or are you simply milking your employers time????:QSo basically the reason for your whining is the wording on AMD's press-release? Seriously, don't you have anything important to do? Like I have said several times, all press-releases are like that, get used to it.
EXACTLY my point! You're catching on........point out exactly where I stated they did.......NO company can state they have the "fastest" CPU because it is statisticly immpossible to have the fastest chip in every category...........What does make CPU in to "worlds fastest CPU"? Intel can't claim that title either.
Fact is though, they do not have the "Worlds Fastest CPU" right now! As far as Intel...........I'm sure you could find a statement similar and it would be just as wrong and just as false as this statement!!!Hey, the press-release only speak about what's here and now, not what will happen in the future. I bet I could find press-releases where Intel releases "Worlds fastest" 233MHz MMX Pentium![]()
Yes, unlike you.................:QYou had a point?
Yes, in fact many times they do and for legal reasons........stop cutting yourself down.....you seem quite able to figure out at least simple things........Do Intel, Ati, NVIDIA etc. make those disclaimers? Why should they put them there? So people who are low on intelligence understand what they are trying to say?(j/k
Sorry son, but you have proven me wrong nowhere or in any way..............Sorry, I already proved you wrong on that one, you have to find something new to say.
Exactly, you have know desire to actually hear or see the truth, you only folow your "agenda" which limits you to only what you want to see and believe..............Sorry, I have better things to do that to read each and every thread you have participated in. Nor I have no interest in following you around and read everyone of your posts.
Um, correct me if I'm wrong, but that's probably because this thread is ABOUT AMD....................In this thread you have biased towards Intel. You have done nothing but whine about AMD. In other threads... Read my reply above.![]()
You know...up until a week ago, I would never have been able to reply to that...nor would I even consider it possible that the heatsink would pop off.
but a week ago, my friend's Athlon 1.1ghz system which had been running just fine and dandy for the longest time with a retail HSF...well, somehow, it must have been the tension in the clip, it just snapped the lug right off. The heatsink lost contact and the cpu was still on. So it fried
Luckily the heatsink didn't fall or it would have caused even more damage.
Now I have nightmares of my lug breaking while the system is on!
CyrixWhich brand of cpu makes the multiple quoted posts intelligible?
LOL! "Most" claim they are releasing their fastest product to date or a similar statement stating they are faster than a comparable product of different branding........not "The Worlds fastest".![]()
Yes, in fact many times they do and for legal reasons........stop cutting yourself down.....you seem quite able to figure out at least simple things........(j/k
You are whining about wording in a frigging press-release! Get over it already! Just about all press-releases are like that!
GET OVER IT!
I read press-releases occasionally. In all of them, the company in question claims to be the leading company in their field of business and that their products are the best there are. That's just the way press-releases are, GET OVER IT!
You never answered my question (surprise surprise....). I listed the computers I own and mentioned what CPU they have. According to you, that proves that I'm ignorant. How exactly?
Why don't you mention the AMD-systems in your sig (like you do with your Intel-systems). Are you biased towards Intel(<==== Notice the smiley!)?
Good for you!
Well, it's about 9.40pm in here (you know, timezones and all). What I do with my spare time is no concern of my employer.
You are whinging about wording in a press-release. GET OVER IT!
GET OVER IT!
I have read several press-releases where they claimn that particular product is "the best" without offering any evidence. I even remember Intel claiming that "Pentium makes Internet faster" and that "Pentium IV improves the sound-quality of your mp3's!".
I think I know you. Aren't you the same guy who started bombing my PM-box after I and few others proved you wrong in a AMD/Intel-debate? You refused to accept defeat and started to spam my PM-box. Your defence mainly consisted on covering your ears and shouting "LA LA LA! I can't hear you!". History repeats itself, it seems....
And you come here and whine about nothing really. It does show bias (not to mention the earlier thread where you were completely bitch-slapped, but you still refused to accept the truth).
Now to other matter: Could you PLEASE try to make your posts at least remotely readable? Now, I understant that the quoting-system can be difficult, but please, try at least. And those excessive ........... and ??????????? don't actually give good impression on you.
The only comment I'm going to make here is that no, I never "bombed" you with PM's or anyone on A/T for that matter if you have proof that I did.....please, present it!
I'll address you're childish comments through PM's from this point forward as I'm sure others are becoming bored with our dialoge and bantering.
You constantly mention "Get over It" frankly, it appears you need to "get over" yourself
