The best thing about this is that FM2 will stick around.
I think trinity will be a very nice processor for mainstream consumers and general workloads as long as they get the higher clocked versions.
Trinity is a class leading product for sure.
What class would that be? The kindergarten class?
Ahh good, more intel trolls. The more of you that show up trolling AMD threads the better, its a good indication of the threat to intel Trinity really poses.
Yes a 4.5 ghz Q6600 does sound attractive (assuming the performance scales lineally with clock speed and there is no bottleneck). That is a 87.5% overclock. You are over exaggerating the gains from an i5 2500k vs a q6600But honestly, does a 4.5ghz Q6600 really sound all that attractive? It's not going to compete with i5's, because Intel has improved performance per clock 50-100% since 2006.
Wow, "best igpu on the desktop" what a thrill. If you really need a good gpu, add a discrete card. Otherwise almost any igpu is good enough.
So the q6600 is a 2.4 ghz chip. The 2500k is a 3.3 ghz chip, but if it uses all 4 cores and is turboing the max speed for 4 cores is 3.4 ghz (3.5 ghz for 3 cores, 3.6 ghz for 2 cores, 3.7 ghz for 1 core). Thus lets say it has a clock speed advantage of 41% (3.4/2.4=41.6%). If the 2500k is roughly double the speed than it is roughly 41% faster per clock (1.41*1.41=1.99)
41% faster per clock sounds about right, but remember than this 2500K can be taken past 4.5ghz too (more like 4.7-4.8), so it's still at least 41% faster while producing considerably less heat and drawing less power.
I suppose Trinity, if released at ~$100, would have a better priceerformance than a 2500K, and nobody is calling a stock Sandy Bridge slow. Still, that extra $100 buys you 50% more CPU power, and that's per-thread performance too.
It becomes much simpler if we just talk stock.
I have no doubts that trinity will use more power/generates more heat than sandy or ivy but that doesn't mean it will sweat heat like bulldozer does.
At stock though, bulldozer doesn't "sweat heat", does it?
I was under the impression that bulldozer doesn't gulp the juice until you start overclocking it.
That depends on the definition:
Posting that same old graph again? Lets use that benchmark to measure performance, since you think it's so relevant.
Oh look at that, FX-8150 is faster than i5-2500k and within margin of error of i7-2600K
Even better when you can snag one at $170FX chips performance is all over the chart, sometimes right up there with Core i5/i7 boys and sometimes down there fighting Pentiums. I hope they've fixed some of that with this new cpu. IMO @ $189 the FX8150 is not that bad if the end user doesn't mind the extra voltage, heat and all the tweaking that comes with it.
Name calling is the best you could do?
If you don't want to be called a troll, don't be one. So stop derailing the thread troll.
As for Trinity, it will be the perfect chip to build a new desktop with. FM2 compatibility for Kaveri is icing on the cake.
