Question AMD Ryzen Threadripper 9000 “Shimada Peak” spotted with 32 and 64 Zen5 cores
StefanR5R
6,824
10,909
Two caveats: ECC UDIMMs still top out at 48 GB/stick. Bandwidth is reduced at 2 DIMMs per channel.
So yes, as far as applications which need memory capacity per node are concerned, this lets AM5 cut into Threadripper territory only slightly.
Shmee
8,313
3,177
I wonder how much a 16 to 24 core TR would go for, and then the motherboard...and RAM xD
It might be a decent upgrade though. Hoping this makes for a good HEDT platform for gaming.
MS_AT
921
1,846
Wrong. https://www.techpowerup.com/335752/...mory-at-ddr5-6000-cl32-overclocked-speed?cp=1 as I said 64GB/stick is available. It might be crazy expensive but it is there.
In Epyc or if you stick to AMD spec, as the Gskill kit from the link above is rated at 6000MT/s, and has been shown to overclock above that. Yes, the secondary timings are worse than in smaller kits but the BW stays.
Win2012R2
1,281
1,331
Indeed, my bad.
Only matter of time - the fact that 64 GB DIMMs appear in consumer space is very encouraging!
RDIMMs are still pretty much stuck at 64 GB for reasonable price, only recently 96 GB became available at also reasonable money, but anything higher is bonkers.
Reactions: lightmanek
eek2121
3,470
5,141
I am hoping they juice the clocks, for non-Pro variants, at least. Give me the same peak clocks I get on Ryzen!
19,204
I would rather prefer they introduce a new dual socket chipset for the consumer Ryzen. Wouldn't mind paying $1000 for such a mobo and they get to sell twice the CPUs!
Tri-channel RAM would be a bonus (I know they wouldn't be OK going up to quad channel because they would hate to piss off existing TR users).
MS_AT
921
1,846
I understand wishful thinking but this is like the worst thing they could do with dual socket.
New socket with 3 channel support would be much more reasonable thing to ask for.;)
MS_AT
921
1,846
At least with dual socket, you can have TWO CPUs, each with tri-channel RAM which should help LLMs.
Sure, for token generation this should do fine. But for eveything else numa aware software would be preffered and that is sometimes hard to come by in consumer targeted software.
19,204
A compromise is to spread the software threads across both sockets using Process Lasso. I tried on my 128 thread Epyc and it was able to run my non-NUMA aware workload (my rudi benchmark actually) across both NUMA domains using 32 threads from each domain (the limit in Windows is 64 threads max unless you use some trickery). I think it would work the same on a dual socket system if it's defined as two NUMA domains.
Reactions: Mopetar and Thibsie
StefanR5R
6,824
10,909
@igor_kavinski, your proposal relates to the question whether to take a Threadripper or an EPYC. (Or two, as you say.)
  • At some point in time, I didn't pay attention when precisely, Threadripper lost one of its original differentiators from EPYC: Its better price per performance.
  • Now with EPYC 9005 = Turin, EPYC's maximum core clocks also shot up to Threadripper levels. Some earlier EPYCs had quite high f_peak already too.
  • What differentiators remain?
    – The possibility to overclock Threadripper of course, for those who have a use for this.
    – A physically smaller socket for which moderately useful air coolers happen to be available. But these have their well known performance limits. The only difference between TR5 and SP5 air coolers is that the top dog, Noctua, offers a TR5 cooler but not an SP5 cooler.
    – A southbridge on board… which nobody needs when there are plenty of PCIe slots.
    – Let's see if Threadripper 9000 introduces any new differentiators.
So if you want a dual socket platform, or really want a platform with a huge core count or/and plenty of memory channels — EPYC is there as a viable option. Expensive alas, but as I said, Threadripper is just as expensive now. Or more expensive even, as it befits a unicorn platform.
LightningZ71
2,660
3,346
Dual socket consumer Ryzen? Hmm...
Upgrade all the PCIe lanes to 6.0
Make the two x4 links for the SSDs the processor to processor x8 PCIe 6.0 coherency link. (64GB/sec, more than a quadrant like on Epyc Rome)
X4 6.0 to the I/O chipset, two of them for dual x970, 48 PCIe 5.0 lanes, +40 other usable lanes.
Just dreaming...
MS_AT
921
1,846
This trickery is called reading documentation ;) https://learn.microsoft.com/en-us/windows/win32/procthread/processor-groups
And yet people buy these so somebody might need them, hmm (no I don't know the volume but since Gigabyte and Asus bother with the mobos then they at least break even)
At this point you have made the physical package big enough to fit 2 additional CCDs, since the core count is matched you can free the intersocket links as the second socket is no longer needed so you get more usable PCIe links. Hmm, sounds like a Threadripper;)
LightningZ71
2,660
3,346
Um, no. It's the same physical package for both processors. The only major change is the additional mode for the PCIe links coming out of the I/O chiplets (already demonstrated know how from Epyc). The motherboards needs to be EATX, and you need double the on board I/O controller chips.
LightningZ71
2,660
3,346
What would be REALLY cool is if you could use an X3D processor in the first socket and a normal one in the second. For Zen5, that could look like one 12 core X3D CCD and one normal CCD in the first package, and two 12 core normal CCDs in the second. 48 cores, 4 channels, 12 with VCache.
MS_AT
921
1,846
Ah I did not spot the 6.0 -> 5.0 thing. Still, this will be usable but carry some BW limitation which might not be ok for some use cases, but might be fine for others.
This could be done on package too, I am not sure where cost balance would be better, but the ease of use would favour single socket solution.
The author of Rapydmark is a much more accomplished developer than I could ever be and he didn't implement this so it's bothersome enough to be called trickery.
There might be a lot of different reasons why this was not implemented, so I would not assume it to be some sort of trickery. Unless you heard that from the dev himself.
Thibsie
1,171
1,380
Why ? People are who ing because 9900/9950X3D are hybrid Cpus and you'd like to go to the same situation here ?
I probably just don't get it...
19,204
Flexibility, I guess. Run the application on the best socket suited for it.
In Windows, you can do that with the start /node command and specify the NUMA node number to run the application on.
StefanR5R
6,824
10,909
What differentiators [between Threadripper and EPYC] remain? […]
Take a look at the block diagrams:
ASRock WRX90 WS EVO (via geizhals.at)
ASUS Pro WS WRX90E-Sage SE (ditto)
There is truly nothing — workstation-specific or otherwise — dangling from Promontory 21 which couldn't be provided by either the TR5 northbridge a.k.a. sIOD, by a generic 3rd party controller, or simply left away. Even audio is provided by the sIOD.
Unsubstantiated claims:
– Nobody is lining up for Threadripper mainboards specifically because they feature the Promontory 21 chip.
– The board makers put it there because AMD told them to.
MS_AT
921
1,846
My unsubstantiatied claim would be that you simply trade convinience for flexibility. I mean with Epyc you have pretty basic I/O on the back panel and you need to fill in the gaps yourself. This way you get exactly what you need but you need to invest time to obtain the extension cards. With Threadripper most of stuff is already provided on the back panel, so you get a utility for a desktop user out of the box so to speak.
