According to ComputerBase.de Primitive Shaders, and High Bandwidth Cache Controller are "inaktiv" in drivers.
High Bandwidth cache still can be switched "on" in drivers.
Quotes, translated, about Primitive Shaders: Problem: This function is also currently disabled in the driver. Vega currently only uses the traditional pipeline. When does this change? AMD does not call an appointment.
About High Bandwidth Cache: Problem: Currently, the HBCC is still switched off by default because the experience gained is not sufficient to activate the HBCC consistently. However, this can be changed in the Radeon Settings menu. Then, on the Radeon RX Vega, you can configure how much memory the High Bandwidth Cache Controller is to use as extended GPU memory - a maximum of 64 gigabytes is possible.
So in the end: it is not functional GPU, yet, with very important features being disabled still. Great release by AMD.
This makes it the worst GPU launch ever. If AMD cannot develop proper driver software for probably their most important GPU launch in 5 years and cannot even utilize the hardware features designed what is the point. One thing is obvious. RTG needs better execution. Nvidia will get to >80% market share once Volta launches.
