Hi,
It's VGA issue, and I would like your suggestions what options to change in order to try correct this.
It happens almost every day.
I'm 100% percent sure it's due to VGA card because I took it out of PC and used integrated card for few months with 0 issues.
As soon as I put AMD card back in PC - same old story.
If I leave PC unattended for some time, monitor will go to sleep and system will freeze.
It will not happen every time monitor goes to sleep.
It's not only "no signal" issue but PC is frozen and only way to get it back is to hit reset on the case.
If I hit "caps lock" on the keyboard I see that "caps lock" indicator is not lit, that way I know system halted.
Facts :
It happens with all (latest and old ones) AMD drivers, but at the moment I have old Crimson 16.11.5
My MBO is Haswell H81M with the latest BIOS
I have MSI Afterburner installed and ULPS turned OFF
It's not power outage issue or something similar - games work 100% OK
I've just disabled "PCI express power link management" in Windows to see if it affects it
Any suggestion is welcome
Facts :
