You really prefer that setup over something like a 40-50 inch 4K monitor?
It is hard to ditch multi-monitor. What you see is a video of monitors using not the best camera, you must see when playing in front.
But I agree, my monitors are from 2012, next setup will be something top of the line. I'm milking my system until something really worth it releases. (Like 16nm GPUs)
I'm going to try to replicate your set up with 3 x 2560x1440 monitors. Does it matter how it is connected to get those flickering on idle? Because I see you are using 3 adapters (Bizlink and Accell are the same company btw). Please give me some time to do this.
what is the exact model number of your graphics card?
You said it worked fine in 2011, but that was before you got your 2560x1440 monitors in 2012. I am assuming the monitors you owned in 2011 for your eyefinitiy setup were not 2560x1440 or higher resolutions?
Is that your rig? Because it's awesome. The Quad Damage sign takes me way back. I don't want to take your thread off topic so reply via PM if you wish.. but are those Audio Engine A5+s? I'm looking at either those or Klipsch Promedia but leaning towards the Klipsch because I don't have much deskspace.
It is doing it to people with triple 1080p monitors. And I don't want 4 cards with memory running at 1000mhz all the time. ( And when you say that to me, it's like saying, but why don't you disable all your 3 other cards and play on one single monitor and set the resolution at 1080p so you don't get any drivers issues.)
UPDATE: BAD UPDATE
Just a little history: I was on driver 15.6 until September. It's then I decided to try 15.9.1 and notice the flickering issue on desktop, but back then I also noticed a bug while playing games...every games but I had so many issues recently and trying to fix the 2d bug that I forgot about the games bug. I tried many drivers to soon realize that any drivers above 15.6 was causing issues (15.7 and up), the issue mentionned in this thread actually.
I also found out a PSU problem I had with my Lepa G 1600 http://forums.anandtech.com/showthread.php?t=2455424 . So I RMAed my PSU and bought an EVGA SuperNova 1600T2 and my shutting PC issue went away. This process took around a month or so and I just received my RMAed PSU this week. So long process: diagnose PC, realize defective PSU, send PSU to RMA, buy another better PSU, wait for the new PSU, receive new PSU, install new PSU, cable management. This whole PSU problem made me forget about the 15.7 and up bug.
So for people following this thread, it took a while to diagnose the 2d clocks issue/flickering and to try to find out the best workaround so I settled for GPU Tweak 2d clocks (idle) set at 1250mhz so the desktop flickering went away. So with GPU tweak set accordingly, this issue in the video doesn't appear anymore on desktop https://www.youtube.com/watch?v=iEDeIxsWroI
So with all those issues I had for the past two months were solved and put aside, I decided to start back gaming, gaming for long period... it's then I realise the game stuttering bug was still present when playing for a little while. I have been working on that issue for the past two weeks and I now have a conclusion: since 15.7, there is a bug issue with display port cable/monitor with 2d and 3d.
In the video bellow, I can play for like an hour or less without issue and then stuttering and sound cracking appear after a while, I have to unplug display port cable (or restart PC) to remove the bug and then I can play for another hour before the bug gets back... as shown in the video below:
https://youtu.be/EgCBw4zgfXQ
So in other words, the bug I'm experiencing in this thread is appearing on 2d clocks and 3d clocks, the only workaround I have is for 2d clocks. For 3d clocks I have to unplug and plug back the DP cable everytime the bug appears during games (as shown in the video above)and by the way it appears in EVERY GAMES and even if I quit a game and go in another game, the bug will be there too, the only solution is to restart PC or unplug DP cable and plug it back.
No issue with 15.6 but missing many crossfire profiles.
PLEASE AMD, fix your damm things
I am not sure if its driver related now. Sure seems like the monitors haven't a clue what refresh they are running at until you unplug and reinitialize. Did you ever wipe your OS yet and do a clean install? (Sorry if I missed that above)
Hello, I have two BenQ GW2765 monitors that are connected via DisplayPort and HDMI to two R9 290X video cards running with Crossfire enabled. I was looking forward to having this extra monitor help me when I work, but has instead given me more work just to get them to stop flickering. After about 15-20 minutes after logging in, both screens will begin to flicker. I've tested the cables and with each monitor just on by itself to see if a monitor or cable was bad, but they work fine, as long as it's not set in a dual monitor setup.
I've tested around and found that when they both start flickering, if I play a YouTube video and full screen it, the flickering stops on both monitors. So, it seems like it might be something with the drivers. I'm not sure and am tired of this problem. Does anybody have any ideas?
OS: Windows 10 Home 64-bit
AMD Driver version: 15.12
Video Card: MSI R9 290X Battlefield 4 Edition (GPU Clock/Memory) 1000Mhz/1250Mhz
ASUS ROG R9 290X (GPU Clock/Memory) 1050Mhz/1350Mhz
Thank you in advance!
Karlitos; you can also tweet AMDMatt
I have wasted over 150 hours trying to solve that issue. Screw that and screw AMD.
I feel your pain since you spent so much $ on flagship cards and water-cooled them and then got such a nice monitor setup. Just sell your 290Xs and get 2 after-market 980Tis and then next year re-evaluate the GPU landscape. If you get 2 MSI Lightning cards, they run so quiet, you don't need to spend $ on water-cooling them.
the problem is nvidia has their own issues with multi monitor; and sli just isn't has fast as crossfire when they are both working.
as I said I'm wondering if its not a driver issue but controller issue with the monitors; is there any new flashes for the monitors?
