http://www.businesswire.com/cgi-bin/f_headline.cgi?day0/220570444&ticker=amd
AMD's demonstration featured "Hammer" running both a 64-bit Linux and 32-bit Microsoft(R) Windows(R) operating system. The AMD "Hammer" processors were manufactured on 0.13 micron, Silicon on Insulator (SOI) technology, which together enable higher performance and lower power consumption.
Update: According to Extremetech (courtesy of Mr. Ice
) AMD's Freb Weber said the following:
Clawhammer processors, which are designed for PCs and low-end servers, will be on sale in the fourth quarter.
In addition, Freb Weber also revealed the following:
Clawhammer, like the other members of AMD's Hammer family, uses an X86-64 architecture, which can run 32-bit as well as 64-bit code. Weber said that the chip was expected to run under a native 64-bit OS with 64-bit applications, a 64-bit OS with 32-bit programs, or under a true 32-bit OS and using 32-bit applications.
Update: Good old Anand reveals some ClawHammer and SledgeHammer pics for our viewing pleasure. Here's a summary of all the important info:
The first thing we noticed about the CPUs is that they look a lot like the Socket-478 Pentium 4 processors. In fact, AMD did borrow quite a bit from Intel in designing the packaging of the CPUs as both the ClawHammer and SledgeHammer parts feature integrated heat spreaders (IHS), a technology which Intel has been using for almost two years now. This means that there will no longer be any horror stories of crushed cores from poorly installed heatsinks or badly manufactured heatsink clips.
By far the most interesting thing about the CPUs from a physical standpoint is their pincount. The ClawHammer has 754 pins (up from 462 on the Athlon and even up from 603 on the Xeon) and the Sledgehammer has a whopping 940 pins which is just over twice as many as the current generation Athlon.
The AMD reference board goes by the name Solo, and is a pretty standard ATX motherboard. There is a single 754-pin Socket on the board for a ClawHammer CPU and it introduces what will most likely become the new (or something very similar to it) retention mechanism for AMD's Hammer line of CPUs.
The CPU was manufactured on AMD's 0.13-micron Silicon on Insulator process out of FAB30 in Dresden. Unfortunately it was not running at full clock speed (which is something that Intel's demos usually do consist of), but we were told that the CPU was running as least as fast as the "other" 64-bit CPU out there (meaning at least the 800MHz - 1GHz of Itanium/McKinley). AMD informed us that they were still on track for a Q4-02 release at full clock speed which we've always hypothesized to be at around 2GHz.
The first system was a ClawHammer running 32-bit Windows XP, straight from the box with no modifications. For those of you wondering what OS you'll need to have in order to run the Hammer processors, your current 32-bit OS will work just fine. Granted that with a 32-bit OS you don't get any of the benefits of the x86-64 architecture, one of which happens to be the additional registers made available in x86-64 mode, but it will work. The Windows XP ClawHammer system was running Microsoft Word and Microsoft Excel test scripts nonstop without a hitch.
The next system was an identical ClawHammer system running a 64-bit Linux port. This setup was a bit more interesting; the demo consisted of two windows each with a a ball bouncing inside the window. The window on the left was running a 32-bit version of the ball-bouncing demo, while the window on the right was running an x86-64 compiled version of the same demo at the same time. This was a simple demo used to show that working with 32-bit and 64-bit recompiled applications concurrently was possible on such early hardware and it worked just fine. This system had apparently been up for the past 24 hours without a single crash, granted it was only bouncing balls all day but that's still an accomplishment for 30-day old silicon.
