The best way to gauge which is "faster" and "better" would be to look at relevant benchmarks representing stuff you will do. If you play a lotta games, the A64 is clearly for you. If you do lotsa video encoding and/or video post-processing/resizing, the P4 still has a slight edge. In most cases though, a A64 would be faster than a similarly rated P4(eg. A64 3200+ vs. P4 3.2GHz).
The A64 and P4 Netburst architecture represent 2 different ideologies in micro-architecture. The former has a shorter pipeline, is clocked slower, but does more stuff per cycle by achieving a higher IPC(brainiac), while the P4 has a longer pipeline, is thus able to be clocked faster, but does less stuff per cycle, and suffers from penalties of a long pipeline(speed demon). intel bet the farm on this approach, but it turned out to be a mistake(power concerns and inability to ramp up production past 4GHz), which is why they will be concentrating on their more power efficient and higher IPC, lower clockspeed Pentium-M derivatives in the future.
