Amd 635 IIx4 to ivy bridge.advantages?
monkeydelmagico
3,961
145
Usage is still same. Just bit more gaming like once a week or so. Battlefield and crysis..
I got amd ati 6850 2gb ram.
Budget would be around 200to 250$
Uh oh....gaming lol. Drives up the specs for your build, particularly those two games. Do you live near a microcenter? If so, for around $250.- you can get a 4690k and a z97 mobo. Pretty much anihilates any task you may want to throw at it now, and in the forseeable future.
Gikaseixas
2,836
218
What's 'so-so' about cheap H81/B85 mobos?
Limited features compared to higher spec boards, Fewer SATA3 ports, fewer memory slots, fewer USB3, some don't even offer HDMI, lack of RAID chipset, etc
Pairing a fairly potent CPU such as i5 with a H81 is not ideal.
SPBHM
5,077
440
there is enough of everything.
people buying $50 MBs probably don't care about more than 2 sata III, raid or usb3.0
also 2 memory slots is enough for 8GB or 16GB, which also what most people use...
H81 board (or b85) is fine with a core i5, it's a good combination for good performance/$
Burpo
4,223
473
+1
Gikaseixas
2,836
218
People buying $170+ CPUs usually don't match it with $50 mb. Makes no sense really
SPBHM
5,077
440
well, they should, I'm using an i5 with the cheapest possible MB, and it performs just like an i5 should with an $40 or $300 MB, it's also been running almost 24/7 for 3 years or so.
your programs don't run faster because of how many ports are left empty.
it makes no sense to pay for additional features if you are not going to use them,
docp
206
Which board will have maximum sata ports. I would take that. Currently i am using 6 ports and have none to add up hdd.
ttquocviet90
thamtuquocviet.com
Upgrading to a Phenom II X6 would give you additional snappiness at minimal cost. That's the biggest difference I saw when upgrading my 635 to a 1045T, but overclocking the 1045T stomps all over the 635.
You may even be able to do a FX 4300 or 6300 even though they aren't listed on the CPU support list. The 4300 would be much better than the 635, and the 6300 would be a nicer upgrade over the Phenom II X6.
Gikaseixas
2,836
218
Why so condescending? Who said anything close to that? Take a chill pill dude
:biggrin:
OP i would get something like this:
http://www.amazon.com/Gigabyte-1150-...4&keywords=Z97
and
http://www.amazon.com/Intel-i3-4150-...-1&keywords=i3
Just my 2cents
