Question Amd 3700x , much cooler with Max processor state at 95%
RockNRule
running a 3700x at stock , and the AMD balanced plan
summer heat got me tweaking to get the temps lower, and Im surprised that lowering the Max processor state to 95% , results in a sold 20 degrees cooler avg temp under normal use, with no real (detectable) loss of performance. didnt benchmark, but talking about browsing and even gaming
avg high 60's to low 50's C.
that constant boosting when set to 100% really causes a lot more heat.
consider doing this if your temps run high
Matisse (1st gen) runs pretty far beyond the optimal part of its voltage/clockspeed curve by default. Slowing it down just a little bit will help you dial back temps, especially when you consider that those are hotspot temps.
Matisse is not first generation, FYI, it is Zen 2 and Ryzen 3000.
How do you tune the max processer state?
(Just got a Ryzen 3700X).
I assumed he meant in windows power options. there is an option to set maximum processor state by percentage in there. I used to set my old laptop to 80% to keep the fans from spinning up so frequently. worked like a charm.
Great thread. I would have never of thought to do this. It was kinda like one of those "ahhh haaaaa" moments.
I just tried this on my aging Elitebook 8460p and it works great. The fan noise is a lot more even now and not as loud.
