- Sep 13, 2008
- 7,409
- 2,442
- 146
If you don't increase voltage or clocks to the point where it draws a certain wattage it won't throttle.
Ok that makes sense I guess. Is this still true when mining though?
I've also seen people say the powertune throttling goes away if you're running cards in Crossfire, though I can't test that myself. Anyone running the cards in Crossfire willing to chime in?I've had the same experience as you on my Sapphire 290-loads of temp head room, but as soon as any voltage is added I get clock throttling. It seems to be a bug in the 14.x beta releases, since I don't get the throttling in 13.12s. No matter what, the power limit controls in CCC, Trixx or RadeonPro don't seem to do anything for single card configs in any of the beta drivers. I noticed a slight performance improvement in the games I'm playing with the 14.x drivers so I'm using those for now and I'm good up to 1100MHz/5600MHz on stock volts of ~1.11 with Hynix memory. Hope AMD fixes it by the time the WHQL drivers are out.
For what it's worth LtMatt posted a temp fix over at overclockers.co.uk using RadeonPro: http://forums.overclockers.co.uk/showthread.php?p=25719851#post25719851
Didn't work for me though.
http://www.overclock.net/t/1436497/official-amd-r9-290x-290-owners-club/19610#post_22001037
This post in in reply to me asking why my card was throttling was the first I saw of it. The thread is massive and its mentioned often in there.
Depending on your bios you may not see this issue. Some bios do not have a power target so there is nothing to adjust.
