I just built a system with an a7v133a mobo and the 1.2ghz tbird. Everything boots up and everything just fine, however when i run the Asus Probe util, it reads at around 55, (which i hear the asus probe reads higher temps). I have a stock fan, which i am going to replace with a Globalwin Cak38, which should take care of most of my heating problems (like when running videos, the temp goes up to 59,60). The question is, during games, like counter-strike, after playing it for a while, the screen freezes/hangs/turns into abstract art. At first i thought it was just the CPU overheating, but after reading some threads like this
, i'm beginning to think it might be some other problem?
Here are my specs.
asus a7v133a
amd tbird 1.2ghz
winfast geforce2 pro 64
sb live value
3com nic card
running windows xp rc1... cuz win2k wont detect either of my ATA100 HD's. XP runs fine, everything works, its just this heating thing and CS hanging. I know the A7v133 reads high, but how high, or low, should it be reading?
any ideas?
Here are my specs.
asus a7v133a
amd tbird 1.2ghz
sb live value
3com nic card
any ideas?
