NTMBK
For that particular CPU the limit is ~66c:
http://ark.intel.com/products/77780/Intel-Core-i7-4930K-Processor-12M-Cache-up-to-3_90-GHz?q=4930k
Um, TCASE is not the same as the temperature reported by your CPU 🙄
What is Tcase vs. Tjunction?
These terms are related to processor temperature for desktop and mobile systems based on Intel® Processors. To allow optimal system operation and long-term reliability, the processor must not exceed the maximum case temperature specifications as defined by the applicable thermal profile.
Tcase is the temperature measurement using a thermocouple embedded in the center of the heat spreader. This initial measurement is done at the factory. Post-manufacturing, Tcase is calibrated by the BIOS, through a reading delivered by a diode between and below the cores.
Tjunction is synonymous with core temperatures, and calculated based on the output from the Digital Thermal Sensor (DTS) using the formula Tjunction = (Tjunction Max – DTS output).
http://www.intel.com/support/processors/sb/CS-033342.htm
You are reading TJunction, not TCase.
EDIT: For comparison, here's a Haswell part which lists its TJunction on Ark- it's 100C: http://ark.intel.com/products/76308/Intel-Core-i5-4300U-Processor-3M-Cache-up-to-2_90-GHz
