Originally posted by: DeathBUA
Originally posted by: n7
Hmm wow, i just rechecked this older roadmap
http://www.c627627.com/AMD/Athlon64/
I think it actually might just be right too.
Anyone notice how the FX-62 is a 7x400 CPU according to that? :Q
If that's actually accurate, wow.
Huge jump in HTT speed if that's actually gonna happen!
If that older roadmap is correct then OCing might not be so horrid, take that 4200+ dualie, 333x7, if you can get the HTT up to 400 then you're at 2.8 and FX-62 levels. Not too shabby eh? Thats only a 67 point hop in HTT which could be doable even on the earlier revisions and Mobo's
That roadmap was good in the days of 2004, 2005, but today, it is out of date. No one even updates that site anymore...
BTW no way was that a Feb 2005 update. It was a Feb 2006 update. I'm almost certain because I saw it updated almost every few days back in 2005 up until fall where they had less to fix[/]
That roadmap may be old, but the newer roadmaps indicate the AM2 chips as having an HTT of 200 whilst someone who actually has a chip has confirmed the HTT is at 333 ... which has to make you wonder.
Yeah, that's updated from 2006 i'm sure.Originally posted by: Mogadon
[BTW no way was that a Feb 2005 update. It was a Feb 2006 update. I'm almost certain because I saw it updated almost every few days back in 2005 up until fall where they had less to fix[/]
I didn't even notice it said 2005 there.
I'm starting to think that "old" roadmap might just be right, or at least right for the higher end models like the 5000+
Maybe lower end models will be 200, other 333?
All i know is it'll be interesting to see.
One thing i found interesting is that AT specifically said nothing about native HTT speeds in their AM2 preview 😉
Could be cause they aren't allowed to maybe 😀
AMD Athlon 64 X2 (Windsor) is expected to be released on June 6th for the Socket AM2 platform on a 90nm SOI process. Windsor is a dual core CPU featuring AMD's Presidio Security technology and Pacifica Virtualisation technology. Windsor will introduce a new Socket AM2 platform (940 pins) and is expected to feature DDR2 800 support and contain either a 2Mb (2 x 1MB) or 1MB (2 x 512KB) L2 cache. Windsor is expected to feature better power management to previous steppings and lower power consumption through the optimisation of transistor leakage currents. The fastest initial version is the 5000+ which features a clock speed of 2.667Ghz running on a 333Mhz FSB (8x333Mhz).
AMD Athlon 64 (Orleans) is expected to be released on June 6th for the Socket AM2 platform on a 90nm SOI process. Orleans is the cut down version of Windsor, featuring a single core design with 1Mb L2 cache alongside the features of Windsor such as DDR2 667, Presidio Security technology and Pacifica Virtualisation technology. Like Windsor, it will be built for the Socket M2 platform.
Originally posted by: Oemo
Some more food for thought, the 5000 has a date of 0603. Means it was made in the third week of this year. If the OP is right then AMD has kept the 333HT under wraps since atleast January.
This is true. It might not make any difference in performance at all. And this may or may not be true. I don't know the OP and we have only seen the IHS of the chip and no other verification.Originally posted by: jiffylube1024
Nothing surprising about that. They've probably had alpha silicon for a year now. Plus there's nothing conclusive about the 333HT, and it's nothing to jump up and down about even if true...
If legit (which I'm sure it is), it's from a test production run, which companies have to do to make sure they can manufacture the product before they actually launch it.
Remember that Conroe setup that Anand tested a month ago? That was obviously manufactured in February at the latest, yet Conroe doesn't actually launch for 5 more months.
Originally posted by: JAG87
EXACTLY, neither did Tom.
you figure they get an ES chip, that they would give you more detailed info, like HT and multiplier, because I am sure that people are interested in knowing how to overclock these new chips, but NOBODY said anything on HT speeds and multipliers. I am starting to get a feeling that AMD requested for that information not be released and sent a crippled cpu, just to screw up the preview benchmarks and make people think that AM2 is nothing better then 939. just watch them pull out a chip that outperforms 939 by a large gap...
Ok, Just so you guys know having a higher HTT base clock will not yield better performance at all. If you wanna test it just benchmark your CPUs at 200x9 and then at 300x6. Performance should pretty much be the same if you also use a memory divider to keep the memory from being overclocked.
Originally posted by: Fox5
Bah, don't use a divider, since the dawn of overclocking, it's always been important to keep the memory in sync with the bus to achieve max performance!
Ever since AMD's onboard memory controller, which drastically cuts latencies, you no longer need to keep the memory in synch with the HT clock.
Heck, the A64 doesn't even use a true traditional FSB!
Just because the impact is lessened doesn't mean it isn't there.
Just because it's there it doesn't mean it matters in real world applications.
In that case you have no reason to be concerned about AM2, or any athlon 64 beyond a 2800+, since the performance won't really matter in most real world applications.
Come on, AM2 is only giving a 2-5% increase over 939, that's the same kind of performance increase that can be gotten out of slightly playing wiht memory settings, and most people say it doesn't matter.
Originally posted by: guoziming
um... so if AM2's HTT speed is higher than 200, would that mean increased performance...?
