Alternator Issue / Toyota Corolla
boomerang
18,883
641
Yes it bug me a lot . Hope i will be able to solve it with some help .maybe i add something to the alternator wiring .any help ��
Check ebay like steppinthrax suggested or find another source locally for the rectifier. You can't "add" anything. You need to 'change' something. The resister needs to be changed.
How much time do you really spend with the key in the on position?
My cars have retained accessory power so if I'm waiting in the car I just turn the key to off and the radio (and other things) stay on for ten minutes. I just reset by turning the key to on and then off. If you have to have the key on to listen to the radio, I understand why it would bother you to be looking at the that bulb.
You gotta do what you gotta do I guess.
emmuscat
15
Hi boomerang nice nickname , It will take only till the heater bulb is of around 8 seconds :) .But since i know about it :mad: i go mad .
So thanks everyone i will look on ebay and try and get one ,Since i live in Malta and few shops sell them and very expensive .
Model Number of rectifier 27357 63020
