Alpha PAL6035 with the Sunon 60mm fan in an Epox 8kta3
techs
28,559
4
The reviews say this should be very quiet. Will it fit in the Epox board? Is it powerful enough for an Athlon 1ghz with no overclocking? thanks for any help.
Wingznut
16,968
Excellent fan setup. I have that same HS/fan running my P3-700e @ 1ghz, with no problems.
Phunktion
2,502
It'll fit just fine.. that's why people buy the 6035 over the PEP66.. because of the space factor.. should fit just fine on your MB..
Phunktion
2,502
BTW I agree.. that Sunon with this HS is the perfect ratio of db vs. cfm.. I use it myself to OC and it's just perfect for me..
goggleax
213
I use that setup too. I still think the fan is too noisey though. Although a PEP setup should fit on the Epox too so...
JJordan
1,069
Can you power this one with teh MB, or should I get a 4 pin to 3 pin adapter ?
goggleax
213
You should use an adapter (just to be safe). Also - the Sunon fan has a whiny motor noise - I think I am going try one of the more quiet Panflo's or Denki's.
Just my .02
