Originally posted by: IBuyUFO
I call shens! No one could be that stupid.
6mA right across the heart can be lethal. If it's passing through your body, you would also lose muscular control. So even if it's not going right across your heart, you could wind up drowning, unable to get yourself out of the tub.Originally posted by: MrPickins
Originally posted by: MisterJackson
Mythbusters figured out that it's 6 AMPS across the heart for a kill scenario. Most appliances they tested in a tub (without a ground fault interrupter of course) hit the kill mark or well above.
That was in a tub of water though. I imagine just being wet from a shower improves your odds of surviving a great deal.
6 amps? You need to watch that episode again. It takes far less than 1 amp across the heart to kill a person. Closer to 100 mA.
TV in the shower strikes me as a very bad idea.
1) Moisture + electronics = bad
2) Sealing up the TV to keep it dry = a well-roasted CRT. Those things NEED to have their air vents totally open to prevent overheating and a possible fire.
3) A custom TV mount must be made to be very secure so that it doesn't happen to fall down while someone is in the shower. It could shatter, spewing lead-laden glass everywhere, not to mention that the CRT holds a charge of about 30KV, and there are various capacitors which will also store a few hundred volts. Plus there's the mains feeding right into the whole circuitry too. Tack on the fact that there's a convenient ground connection (the water mains), and the fact that you are standing right in the path that the electricity is REALLY going to want to take, and it all just sounds like a really really bad idea.
The only other option I see would be to create a small chamber which is sealed from the shower stall, but vented on top, preferably with some sort of fan to ensure good ventilation. Put the remote into a plastic ziplock bag, and it should be usable.
Other option, as has been suggested: Go a few minutes without the damn TV. Or get a Tivo, or a PVR card for your PC.
Originally posted by: Stumps
sounds like somebodies trying to score a Darwin Award.
TV in the shower...now that's just stupid.
I believe it's 60 milliamps, not 6 milliamps. And, mythbusters didn't figure this out... they used this number from other source. What they tested was if a toaster or whatever dropped in the shower would result in a current high enough to kill someone.
Plus, a lower current causes the diaphragm to tense up; thus, while the current may not zap the heart, you end up dying because you can't breath (as long as that current is maintained.)
Originally posted by: BrownTown
So, about that show, someone earlier said that was without fault protection right? Or did they see if the circuit breaker woulda closed on the fault?
Posts: 38414 holy sh|t! I think thats gotta be by far the most posts by someone I've ever seen by anyone in any forum!
wow, now you have 3 more psots in 30 seconds!
A circuit breaker will trip due to the very high current going though the water. There would not be a ground fault since the water is in the tub and not ever gonna make a path to ground. So groud fault protection = worthless, overcurrent protection = usefull if the current through the water is high enough to trip the breaker.
Originally posted by: alien42
a tv in the shower, what a stupid and pointless concept
Circuit breakers trip in like 4 cycles, thats fractions of a second. Also, current can sure as heck flow without a path to ground. If you want to just arbitrarrily say that the center tap on the transformer is grounded then you can act like you need a path to ground and then you can argue symantics and such, but I'm talking about no fault to earth ground.
