All Season/Snow Combo Tires - Who makes them?
My wifes old T- Bird sucked on snow . So I got aset of tires like your talking about from firestone, After installing it could plow snow . but there is a down side. More road noise. But not bad. These are rear drive cars. These are not snow tires there allseason . I was going to go look and see what there called but dam its cold and I don't get around very well . just go to firestone they have the tire your looking for but just buy 2. Its my beater car for hauling racing crape around . Last winter I only filled the car 1 time . So far this year I haven't gone to get it filled .I don't get out much .
Do those of you with snow tires get them on new rims or mount them on the same rims? I saw Zap's answer, but he also changes his own tires. I won't be doing that.
I was looking up snow tires for our new car. To get the same size (205/50R17) would cost $520. With rims, I can do 205/55R16 which are cheaper tires, but the TPMS sensors I would need on the new rims bring the total cost to about $1000. I understand that I save money on mounting ($40/yr vs $160/yr), but is there any other reason to get a whole new package and not just new tires?
I was going to get a set of ExtremeContact on alloy rims at Crappy Tire (Candian Tire, at $1248 CAD ++ lug nuts) but I dumped them after they gave me the run around on last Thursday & Friday.
I ended up with a set of Cooper Weather-Master S/T 2 for $642 CAD installed at Big-O yesterday and it performed well in dry and slightly wet condition. It feel a bit soft around corners, road contact is less than the Michelin Primacy MXV4 allseason. It is also nosier than the Primacy MXV4. The Weather-Master is smooth with some road noise up to 120 KPH and feel a bit soft/insecure at 140-150KPH on dry pavement. While Primacy MXV4 is sure footed up to 160KPH on dry pavement.
Interesting.
I was able to get Kingstar SW41 (Hankook rebranded w409 ipike) for $500 all said and done (used my OEM rims)
The tires themselves take a bit of a beating being removed and reinstalled again and again, and there's always the risk that the installer will damage a tire during this process. You might want to look into what the effect of not running a TPMS sensor is on your system - if it's just a fairly subtle warning light I could live with it, whereas if it's an audible alarm that won't go away it would be unacceptable. Fortunately my BMW E90 uses a TPMS system that doesn't rely on sensors on the wheels (the newer ones do have this, but my older one just monitors wheelspeed to look for a flat), so I don't need TMPS sensors in my wheels.
Separate rims. it is not that expensive since winters you just run steel rims.
For cheap steel rims contact a wrecker, they are better typically than the aftermarket ones and usually cheaper too
I live in MN. Just got 4inches of snow overnight and we have a total of 10" YTD. I'm on some Bridgestone RE960AS's and these are rated for high performance all-season tires.
Got the same Pole Positions on my LS here in IA. Wouldn't even dream of using them in the winter - that's what the narrower Michelin Xi2s (215/55/17, stock size is 235/50/17) are for 😉
Never heard of them. Aren't all season tires are supposed to be the hybrid of summer and winter tires already? With the rear wheel drive on my GTO, I had to get a set of snow tires. All seasons just weren't cutting it. I just bought two though, for the rears and a second pair of rims to have them mounted on. So now I can swap them out myself rather than going to the tire shop and getting them mounted.
I haven't tried them. I use all season on one car (kind of suck) and snow on another (suck less). When these snow die I am absolutely getting more snow tires and getting studded, too.
I believe both Volvo and the local tire shop said that the TPMS is required. I'll ask again and check the internet. It's a 2010 Volvo S40.
The bundle would've been a good deal if not for the TPMS.
+1 Plus the bonus is that you keep the salt from screwing up your nice summer wheels 🙂
Okay. That's a very good point. They aren't fancy wheels, but they're still quite nice.
My car happens to not have TPMS. On some other Mazdas, if you don't have TPMS you just have a light lit up on the instrument panel, but you'll want to check yours to see. Unless they put TPMS into the spare tire, I don't think they'd make it too obnoxious.
I've heard that higher profile tires work better in the snow, so that might be one benefit of going tire/wheel and one under in wheel diameter. However, you are already at a 50 series, and I think that rule of thumb might be more for really low profile tires.
Uh, how about some nice studless tires? Studded tires tear up concrete/asphalt and can't be driven on the road.
Even if you need to get another set of tpms, I think it is still a better deal. you can run smaller size rim, which translates to cheaper tires. If you only have 1 set of rims and sensors, you need to mount and remount twice a year. That will add up to more than second set of rim and sensors in no time.
