Discussion All Custom APUs Discussion Threads
Tigerick
942
857
Qualcomm's ARM SoC Lineup
ARM/x86 SoCDateNodeDie Size (mm2)Default TDPCPUGPUFP32 (FLOPS)ModelRAM + SSDLCDBatteryWeightSRP
G3x Gen 2Q4 2023N415 WX3 3.36GHz 8-coreA32 1GHz3072AYANEO Pocket S12 + 1281440p 6" IPS LCD6000mAh350 g$589
8 Gen 2Q4 2022N4118.48.5 WX3 3.2GHz 8-coreA740 680MHz2089Retroid Pocket 612 + 2561080p@120Hz 5.5" AMOLED6000mAh320 g$259
G2 Gen 2Q1 2025N4PX4 2.8GHz 8-coreA22Retroid Pocket G28 + 1281080p@60Hz 5.5" AMOLED5000mAh280 g$219
7+ Gen 3Q1 2024N4P89.545.5 WX4 2.8GHz 8-coreA732 950MHz1459
G3 Gen 3Q1 2025N4PX4 3.3GHz 8-coreA33 1.05GHz3226 ?KONKR Pocket Fit12 + 2561080p@144Hz 6" LCD8400mAh386 g$329
8 Gen 3Q4 2023N4P137.38 WX4 3.3GHz 8-coreA750 903MHz2774AYANEO Pocket S212 + 2561440p 6.3" IPS8000mAh428 g$499
Steam Frame16 + 256Dual 2160 x 2160 LCD21.6WHr440 g?
8 Elite Gen 4Q4 2024N3E124.18 WOryon 4.32GHz 8-coreA830 1.1GHz3379KONKR Pocket Fit Elite12 + 2561080p@144Hz 6" LCD8400mAh386 g
AYN Odin 3 Pro12 + 2561080p@120Hz 6" AMOLED8000mAh390 g$399
AYN Odin 3 Max16 + 5121080p@120Hz 6" AMOLED8000mAh390 g$449
8 Elite Gen 5Q3 2025N3P126.2Oryon 4.61GHz 8-coreA840 1.2GHz3686
8 Elite Gen 6 Pro?Q4 2026N2P~5000Steam Deck 2 ?
AMD Aerith+Q4 2023N6131~15 WZen 2 3.5GHz 4-coreRDNA2 8CU 1.6GHz1600Steam Deck OLED16 + 512720p@90Hz 7.4" OLED6470mAh640 g$549
128-bit LPDDR5
AMD Z2 AQ1 2025N613115 WZen 2 3.5GHz 4-coreRDNA2 8CU 1.8GHz1800ROG Xbox Ally16 + 5121080p@120Hz 7" LCD60WHr670 g$599
AMD Z2 Extreme AIQ1 2025N4P23328 WZen 5 5GHz 8-coreRDNA3.5 16CU 2.9GHz5900 SIROG Xbox Ally X24 + 10241080p@120Hz 7" LCD80WHr715 g$999
Next Gen XBox Consoles and Handheld Preliminary Specs
ROG Xbox Ally / SteamDeck OLEDPS6 Handheld ?ROG Xbox Ally XPS5Steam MachineXbox Series SXbox Series XX2 ?PS5 ProPS6 ?
Date2025Fall 2027 ?20252020202020202024Fall 2027?
CodenameAerith PlusCanisStrix PointMagnusCustomOrion
ModelZ2AZ2 Extreme AI
N63 nmN4PN6N4 + N6N7N7PN3P + N3P ?N4P3nm Single Die
131135 mm2 ?233 mm2260 mm2197 mm2360.45 mm2144 + 264 = 408 mm2279 mm2280 mm2
CPU4 x Zen 24 x Zen 6c + 2 x Zen 6 LP3 x Zen 5 + 5 x Zen 5c8 x Zen 26 x Zen 48 x Zen 28 x Zen 23 x Zen 6 + 8 Zen 6c
12MB L3
8 x Zen 27 x Zen 6c + 2 x Zen 6 LP
8-12 MB L3?
16GB DDR5
GPURDNA2 8CURDNA5 16 CURDNA3.5 16CURDNA2 36CURDNA3 28CU SI?RDNA2 20CURDNA2 52CURDNA5 68CU
12MB L2 ?
RDNA2 60CURDNA5 52CU
10MB L2
Memory16GB 128-bit LPDDR5-640018GB 192-bit LPDDR5x-853324GB 128-bit LPDDR5x-800016GB 256-bit GDDR68GB GDDR68GB 128-bit+ 2GB 32-bit GDDR610GB 320-bit GDDR6 + 6GB 192-bit GDDR630GB 192-bit 36Gbps GDDR7 ?16GB 256-bit GDDR620GB 160-bit 32Gbps GDDR7 ?
Memory Bandwidth102 GB/s204 GB/s120 GB/s448 GB/s224 GB/s560 GB/s864 GB/s576 GB/s640 GB/s
basix
336
651
Or they simply had some space left, to put another core on the Die.
But 144m2 for the SoC part seems to be rather big. Are there additional memory PHY on the SoC Die? Or does the GPU Die really have a 384bit SI instead of 192bit?
Reactions: Tlh97
MS_AT
939
1,860
Probably 10C/20T in the console, with one extra Zen6c for binning
So 2 + 8 or 3+7? The latter looks even more weird (sorry if something is not a power of 2 it looks weird ;))
Still I would expect for 12 cores a mix of 8 + 4 dense with 4 reserved for the OS/background stuff, and 8 perf fully available for games. Now the devs will need to make core aware thread placement.
Reactions: Tlh97 and marees
Kepler_L2
1,084
4,683
It looks like the GPU die is just Shader Engines + GPU Front-end, Memory controllers + MALL? And SoC is everything else (CPU, Display, Media, PCIe, NPU?)
ToTTenTranz
951
1,575
Does it make sense to put the NPU far from the GPU cores and caches? That way they can't use the NPU to offload FSR4 or other ML upscalers in games, for example.
marees
2,286
2,894
The speculation is that performance will be between 5080 and 4090/5080 super
Assuming this releases next november what would be the street price of the 5080 super at that point in time ? I don't see the console selling below that
As a sop to gamers, Microsoft could partner with AMD for an RDNA 5 based z3 extreme ? for handhelds by various 3rd party partners
Not sure if microsoft will also partner with AMD for a medusa halo like APU
basix
336
651
They aren't going to run upscalers on the NPU.
Wouldn't that be a really nice use case on APUs? XDNA2 does support FP8 (50 TFLOPS) und is much more powerful than the iGPU in this regard. It would give AMDs iGPUs a quite relevant competitive edge.
When I look at FSR4 Redstone and its upcoming features (Neural Radiance Caching, Ray Regeneration, ML based frame generation, enhanced ML based super resolution), all could potentially benefit from NPU acceleration. Even without RT, only FG and SR would already be worth it.
So instead of having a mediocre gaming experience or using precious Die area for a bigger GPU, leverage the NPU to amortize its cost. At least for gaming use cases. Currently, the NPU is dark silicon for most of the time. If APU gaming gets into the mix, only few people would say no to that and the added cost for the NPU is better leveraged.
Kepler_L2
1,084
4,683
It's a lot of work to port GPU code to NPU, it isn't really that fast and upscaling on the NPU introduces an additional frame of input lag.
Reactions: marees
basix
336
651
I just talk about the matrix accelerated part of the algorithm. Everything else would stay on the GPU. That would not add a single frame latency.
Just look at the NPU as "remote matrix core / accelerator" but as it is on Die, not that remote as if PCIe or something else would be in-between.
Sure, it would be effort but it should be doable nevertheless. Prequisite is that matrix operations are cleanly separated from the rest of the algorithm. If it is intertwined with many other operations, it would get a mess.
We should be able to evaluate that when AMD releases the FSR4 code on GPUOpen.
Kepler_L2
1,084
4,683
There is an extra frame of latency, just look at the Windows Upscaler using the X Elite NPU.
basix
336
651
As far as I know, that one functions completely differently compared to FSR or DLSS.
Edit:
Here is a presentation from ARM at Siggraph 2024, where they describe different ML approaches to upsampling. What they came up with was basically a super-charged FSR2 ("v3 - parameter prediction"):
- "Regular" Upsampling algorithm like FSR2+ or DLSS2+ (FSR2 was the basis in the ARM presentation)
- Filter weight / parameter prediction with a DNN showed best results ("v3" in the presentation; Microsoft's Auto SR is more of an image prediction like "v1" in the presentation). Pretty much what AMD and Nvidia are doing with FSR4 and DLSS2+
Now, if the DNN has clean interfaces (pre-compute/post-compute in the presentation get executed on the GPU, DNN in-between on an "accelerator"), it might get executed on any DNN accelerator HW. Might be matrix cores in the GPU or offloaded to an NPU.
I do not see any fundamental obstacle to that. Sure - datapaths, caches etc. need to be supported and any kind of API to do that on a chip. But as it is possible to move data from CPU to GPU and vice versa, that would also be doable looking at GPU and NPU. Also, no added frames of latency.
In the presentation it is not clear, what ARM has in mind (NPU or GPU acceleration). They just call it "𝐴𝑐𝑐𝑒𝑙𝑒𝑟𝑎𝑡𝑜𝑟𝑇𝑂𝑃𝑠"
marees
2,286
2,894
More code names drop
  1. orion (PS6 ?)
  2. Robin (PS5 handheld ?)
  3. Robin plus (PS5 handheld revision ?)
  4. Canis (Microsoft handheld?)
CORRECTIONS:
  1. orion (PS6)
  2. Robin (PS5 blockchain mining version)
  3. Robin plus (PS5 blockchain mining version)
  4. Canis (PS6 handheld)
soresu
4,251
3,755
Seems very odd for PS6 and PS6 handheld to have opposing codenames tho.
It would have made a lot more sense for PS6 to be Magnus or Majoris rather than Xbox Next.
soresu
4,251
3,755
From a funny situation to see the unveiling of the return of the handheld consoles
I mean, they never left and on Nintendo side have usually been the best selling consoles in any generation.
Given Nintendo are being increasingly full of themselves that may not be the case for Switch 2 this time around.
Sony have a real chance to make inroads this time if they don't mess it up.
If they made a 'lite' version of PSVR to go with it for a HMD/NED in place of TV tethering then it could be just what the doctor ordered.
Something along the lines of Bigscreen Beyond in size/weight would be perfect, with the console acting as the compute/battery/IO 'puck' equivalent to Apple Vision Pro.
Doesn't even need to do full tracked VR, just to display a beeg screen with some visual passthrough.
LightningZ71
2,695
3,394
I feel that there is a convergence window approaching. The handful of gaming cell phones that have been released in the last couple of years show that phones are rapidly closing in on being able to be full fledged gaming systems. Just the flagship phones have had more grunt in their SoC than the super popular of switch for at least 4-5 years and even upper mid range phones now have the capability to nest it across the board.
Sony and Xbox have a slim window to get hardware out in a handheld form factor to bridge their existing customers to something they have control over before we are in a market saturated with phones that can be docked and drive a big screen TV at acceptable levels of performance and mobile games and ports filling the space that S and MS once filled.
basix
336
651
For Switch you could optimize your game. For the huge variety of smartphones that will not work. So performance will always be subpar, despite potentially faster hardware.
But I agree with you, that for many people a docked smartphone could be an interesting solution. With the dock, you might also crank up the SoC power to get more performance.
