- Aug 18, 2003
- 176
- 0
- 0
The jist : My AIW 9700 Pro will not for the life of it produce any sound output, never has really. Unfounrtunantly I never really TRIED to use the TV and such until it was a little too late to return the thing. It's finally annoying me enough to ask someone's help.
I have tried using it's supplied output cable into the line in and microphone jacks of both my SB-Live and the AC '97 onboard sound, no go. Feeding the "CD-Audio" line from the card to the forementioned CD-INs doesn't produce sound either. Nor does feeding it into the TAD-IN or the AUX-IN on the SBLive. I turned off the onboard when working with the live and popped out the live when working with the onboard.
I'm currently working around it by using a VCR to filter off the sound channels and piping it directly into the Live-Drive Co-Ax audio inputs, but this is getting clunky in an ever shrinking computer workspace.
Does anyone know of any particular quirks with the audio for the AIW cards or any of my particular hardware combo?
"Built by ATI" AIW 9700 Pro
Gigabyte GA-7vaxp Ultra w/2400+
SB-Live Platinum 5.1
Most Recent Catalysts.
Most Recent MMC
Yes, everything is installed right (driver wise), and yes, I'm using the right cables (95% sure anyway)
I'm completely befuddled, and if all else fails I could use recomendations on cheap (sub $50) TV tuner cards with decent PVR.
Thanks (hopefully) in advance!
Most Recent MMC
